1996 camry idle rough problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2007, 05:18 AM   #1 (permalink)
View oldcardriver8's Photo Gallery
Hi all,
I just got a automatic camry 1996 le, few months ago. I changed the spark plugs, engine control rod, the water, oil, air filter and thermostat. The car is running nice and smooth when it is moving, when it is in idle, at the light (with break on drive or reverse) the stirring wheel shake (fast shake). I don't understand why it is not doing it in Nutual or park? Could it be something wrong with my transmition?
Thanks
Pete
oldcardriver8 is offline   Reply With Quote
Old 02-18-2007, 09:35 AM   #2 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
Do a search for IAC, Idle Air Control Valve. You'll find many posts describing in detail how to clean it. Start with that.
DFBonnett is offline   Reply With Quote
Old 02-18-2007, 10:51 AM   #3 (permalink)
My car has a check Engine light on all the time. It ran cold in the high way, so I change the thermostat. The thermostat was rusted open all the time, could this accelerate the ICV being dirty ?
How do I apply Sea Form?
thanks
Old 02-18-2007, 10:53 AM   #4 (permalink)
View OEMonkey's Photo Gallery
I agree.
Jumper TE1 and E1, there should be a noticeable change in rpm. If there's no change in rpm or if it stalls out, suspect a faulty Idle speed control valve as mentioned. Very common problem on older camrys.
OEMonkey is offline   Reply With Quote
Old 02-18-2007, 12:44 PM   #5 (permalink)
Gameroom cash: $304355
You didn't mention which engine the vehicle has, nor how many miles on it, but I will assume it's the 4 cylinder 5SFE engine. Some vibration in idle in drive or reverse is normal for this generation 5SFE engine. It's just the nature of the beast.
I do however have 2 suggestions for you. First, your 96 is OBD2 compliant. That means you can go to a place like Autozone and have them check for any codes for you. This is a free service. If you do have a code, this will give you some direction on where to start looking for a problem, if there is one. If there are no codes present, the second suggestion I have is to do a thorough throttle body cleaning. You can clean the idle air control valve while you are in there. There is a square or diamond shaped passage leading to the idle air control valve inside the throttle body. Do a search on this forum for "throttle body cleaning". It has been covered numerous times and there are some good threads on it with some good pictures. The cleaning may smooth out the vibration a bit.
Mike
Old 02-18-2007, 05:41 PM   #6 (permalink)
iTrader Score: 9 reviews
View camryelaine's Photo Gallery
Since the car shakes at idle and not at netural or park, it seems more like engine mounts problem to me.
camryelaine is offline   Reply With Quote
Old 02-18-2007, 07:37 PM   #7 (permalink)
After I got the car I ran it on the high way, and it started to have huge vibration on the engine. I turned out the guy sold me the car had the tire pressure at 50psi, after that I had to replace both front tires. And later I replaced the engine control rot. When I change the engine control rod I had a hard time getting it in place, but manage to do it. While I was changing the rod I change the spark plug as well. When I drove the car I feel the shake on start of Drive and Reverse, but smooth above 1000rpm. If the problem is the engine mount why doesn't it affect park and nutual?
thanks
Old 02-20-2007, 10:07 PM   #8 (permalink)
View marc780's Photo Gallery
Maybe your idle is set a little too high, or a vacuum hose is cracked or you have some other vacuum leak.
Old 02-20-2007, 10:13 PM   #9 (permalink)
The Greek....
GrkBallaG's Avatar
iTrader Score: 13 reviews
View GrkBallaG's Photo Gallery
Word.
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
Old 02-21-2007, 09:20 AM   #10 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
This is always a posibility. What solved it for me after I changed everything you mentioned above (hell, I had the engine out and put on a new timing belt, water pump, oil pump, gaskets, orings, plugs, wires, mounts, you name it) I finally rechecked the timing and found out that instead of the 10 deg the service manual calls out for, I was at about 5 deg. I adjusted it, and my idle went up just enough to almost eliminate the vibration at the steering wheel.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 02-21-2007, 09:21 PM   #11 (permalink)
View deekay140's Photo Gallery
its the motor mounts.
deekay140 is offline   Reply With Quote
Old 02-21-2007, 10:44 PM   #12 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
Try spraying some carb/throttle body cleaner into your iac, it worked for me.
Blackhawk3D is offline   Reply With Quote
Old 02-25-2007, 06:24 AM   #13 (permalink)
how do I check if it is the motor mount?
Old 02-25-2007, 08:52 AM   #14 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
Originally Posted by oldcardriver8
And later I replaced the engine control rot. When I change the engine control rod I had a hard time getting it in place, but manage to do it. While I was changing the rod I change the spark plug as well.Thanks
Maybe this is a regional expression, but in over forty years working on cars, I've never come across an "engine control rod."
Are you talking about an engine torgue strut, or "dogbone?"
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 02-25-2007, 11:20 AM   #15 (permalink)
yes, they are the same, on the manual it is call engine control rod and people tell me it is the mount strut "dog bone".
I use to use 87 octane gas, a few days ago, I added 89 octane gas and the engine seems to be running smoother on stop light stop. Could this mean, it more likely need IAC and throttle control val cleaning?
thanks
07 Camry SE V6 Problem - Service Dept. Stumped - Comments? kkmatuse 5th & 6th Generation (2002-2006 & 2007-2011) 61 06-27-2009 01:45 AM
Rough Idle on 96 Camry acojosh 3rd & 4th Generation (1992–1996 & 1997–2001) 5 05-28-2005 11:49 AM
Idle Speed Problem 1998 Camry 4 Cylinder/Auto cdlubbe 3rd & 4th Generation (1992–1996 & 1997–2001) 0 02-26-2005 08:24 AM
idle solenoid control motor 96 camry rough starts. help? sigmachibri 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-25-2004 06:44 AM
1996 Camry CD player problem snak3uk 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-30-2003 03:58 PM
