3sfe turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2003, 09:51 PM   #1 (permalink)
View high c's Photo Gallery
3sfe turbo
hi this is my first time posting here, heres my Q: I have a 90 4 banger camry with 3sfe engin in it (114 hp/ 130 tq) and I am buld a turbo kit for it (it done) I just need some help about fuel mangment and how much boost will this engin take?
thanks
high c is offline   Reply With Quote
Old 06-23-2003, 10:05 PM   #2 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
here you go
http://www.toyotanation.com/showthre...threadid=17325
I miss my camry....................
smokey8890 is offline   Reply With Quote
Old 06-23-2003, 10:39 PM   #3 (permalink)
thanks man, but the link dose not say if he added bigger injectors.
Old 06-23-2003, 10:48 PM   #4 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
probably a good idea to build up your fuel system, high flow fuel pump, regulator and bigger injectors, its what most people with turbo setups have
-Nick
Nick is offline   Reply With Quote
Old 06-24-2003, 01:26 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Got any pics?
"Skoolin' the unlearned!"
Old 06-24-2003, 01:35 AM   #6 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
A Vortech FMU is your best bet with a 10:1 disk in it. I wouldn't put more than 7psi on it. And post some pics!!! I wanna see this bad boy.
Edit>> Oh yea, you can use a 255lph walbro supra TT 94-98 fuel pump, you can pick them up on ebay for like 85$
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 06-24-2003, 07:11 AM   #7 (permalink)
Wink
Ya my set up is pritty Ghetto. I didnt buy a new exhaust manifold, I just took off the cat and made an adator plat out of some 1/4 steel. I need to find a digital camra
Old 06-24-2003, 07:37 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
What turbo are you using?
For fuel management you can use a Vortech FMU / boost dependent fpr like djprefix suggested or additional injectors installed on the discharge pipe before the throttle body and control it with a AIC (additional injector controller).
Old 06-24-2003, 07:39 AM   #9 (permalink)
its an IHI out of a old 2.3 stang
