Timing Belt? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-25-2007, 09:11 AM   #1 (permalink)
View camryboy01's Photo Gallery
Timing Belt?
So I was at the mechanic the other day and he said I would need to get a new timing belt replaced very soon on my 01 Camry. I asked how much and he quoted me as much as 500! I looked online and timing belts are only 30-40 bucks. So if I buy it online, I should just be able to bring it in and have them only charge for labor, correct? Also, what is the max I should be paying to have it installed?
camryboy01 is offline   Reply With Quote
Old 02-25-2007, 09:37 AM   #2 (permalink)
I'm Cam'd Up
Pimpinda93camry's Avatar
View Pimpinda93camry's Photo Gallery
if he quoted you 500 he also said water pump drive belts. water pump is 150 from toyota, belt is 50 from toyota drives are like 40 50 fro both so he is chargein half of you bill for labor. so in a sense no you will not save any.
but check your quote to see exactly what he is doing.
****NEW 1970 CHEVY NOVA**** MORE INFO LATER
Cold Air Intake
Cat Back Muffler, 5% Semi Matelic Tint
16x7 Proline Alloy, Dunlop SP FM901 225/50/R16
Clarion HU, JL Slash 500/1 , 2 JL 10W0, Silver Star Headlights
Pimpinda93camry is offline   Reply With Quote
Old 02-25-2007, 11:16 AM   #3 (permalink)
G-ma Car? That's Right.
View Blackhawk3D's Photo Gallery
My local dealer charges like $250.
Blackhawk3D is offline   Reply With Quote
Old 02-25-2007, 01:58 PM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
^ should be around there just for labor
and the belt should be around 50bucks, but a shop may charge more
and it's not guaranteed that a shop would use anything but an oem belt since they have to warrantee their work
HaHa
Old 02-25-2007, 07:59 PM   #5 (permalink)
ASE Master, now Realtor
timebuilder's Avatar
View timebuilder's Photo Gallery
The last thing you want to do is to appear to be a smart *ss by bringing a professional your discount part for installation. Either decide to have the work done there, or not. If not, choose another provider. You will generally "get what you pay for."
I have something like 130k miles on my timing belt. The normal service life is 60-90 k miles. On a Toyota, which has a "non-interference" engine, your biggest downside to waiting to replace the belt is inconvenience. When the belt breaks, your Toyota coasts to the side of the road to wait for the tow truck, and unless you have towing coverage, that's an added expense.
I would only install a Toyota timing belt. The japanese are obsessive about the quality of parts like this, and I doubt you could find better.
Courage...Honor...Conquer
timebuilder is offline   Reply With Quote
Old 02-25-2007, 09:07 PM   #6 (permalink)
Well, I can see a disadvantage in that you'd have to retime it. Not that that's too hard, but still, when I changed the belt on the Volvo I did an engine swap on, I just pulled the old one off, made sure the notches lined up, and slipped the new one on.
Old 02-26-2007, 07:09 AM   #7 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
As another poster said, that also includes the waterpump. Since its pretty stupid to replace the timing belt and not the water pump.
It cost be about $520 for the new timing belt, new water pump, and new exterior casing, and all labor. (My plastic cover was all chewed up).
geoff5093 is offline   Reply With Quote
Old 02-26-2007, 08:36 AM   #8 (permalink)
Belt timing is something one should do on EVERY belt replacement. It only take s a few seconds, and you have confirmed the relationships of cam and crank. In the shop, one of the techs shipped a car, an Eclipse with the twin cam motor after a belt change he did, and the cust was complaining of a tapping noise from the engine.
I re-did the belt timing. One of the cams was off a tooth and the balance shaft was nowhere near the proper spot. The timing was off just enough for a valve to be lightly tapping on the carbon on top of a piston. Yikes. Those engines are interference designs.
The decision on the water pump depends mostly on mileage. If you are looking at the initial belt replacement, you might not need the pump. On the second belt, I'd definitely replace the pump AND the tensioner.
Use only Toyota parts, and save yourself a lot of grief. Get two estimates from garages recommended by people you trust, and have the job done right with quality parts.
Old 02-26-2007, 08:59 AM   #9 (permalink)
Thanks for the help guys..
Old 02-26-2007, 09:04 AM   #10 (permalink)
I just meant that sometimes when it's way off it's harder to get things back in place. Yeah, mitsus are interference engines, one of the staff at my school had one and the belt slipped on the highway, bam, dead engine.
Old 02-27-2007, 05:53 PM   #11 (permalink)
View marc780's Photo Gallery
There are couple of good posts on changing timing belts. You didnt say if you are a 4 or V6. So Im assuming yours is a 4.
You can do it and save a lot of money on labor, but you probably should have more than passing knowledge of what's under the hood. If so, why not have at it, i say. Heres my post on doing the V6. And somebody else's on the 4
http://www.toyotanation.com/forum/t149232.html
http://www.toyotanation.com/forum/t160972.html
Old 02-27-2007, 06:31 PM   #12 (permalink)
The Greek....
GrkBallaG's Avatar
View GrkBallaG's Photo Gallery
Dont bring steak to the steak house man...
The SLAMry.....
Slammed, Carboned, 5sp Swapped, Big Braked, RMM Lipped And Ready To Be Daily Driven!
Originally Posted by UfoZ View Post
Tits! Best non turbo Camry there is.
GrkBallaG is offline   Reply With Quote
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
