There is a section on the camshaft that can be held with an open-end wrench to keep it from turning, while you loosen the camshaft pulley bolt. Of course you need to remove the valve cover first.
I couldn't find a picture showing the camshaft in the car with the "hexagonal wrench head portion" visible. So here's an image of the closest thing - you can see the section on the cam that has been clamped in the vise. (Naturally you wouldnt want to use a camshaft lobe for this by mistake).
I will try to "bump" the crack shaft using a wrench and the starter, but how do I brace it when I am trying to tighten it back on to torque (in the opposite direction?)
All you can do is get it as tight as you can by hand. I'd be really careful doing this because if you are a little too enthusiastic, you could make the belt jump time. In other words, DONT use timing belt tension to help you tighten the crank pulley bolt.
It's not likely the bolt will come loose especially if you just use some lock tite blue on the threads and just go ahead and put everything back together.
Then maybe next time you are around some shop that does have an impact wrench maybe they will let you borrow theirs or blip the pulley bolt on a little tighter for you.
