mr2 6spd sequential manual - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-26-2003, 01:15 AM   #1 (permalink)
cam2Xrunner's Avatar
im looking into swapping a 5-spd manual tranny into my 99 v6 camry, and i was wondering if there would be any way to use the sequential 6 spd manual tranny out of a brand new mr2? anyone ever look into this? im amost sure you wouldnt be able to do it but it would be pretty badass if you could.
Old 06-26-2003, 02:04 AM   #2 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
Re: mr2 6spd sequential manual
would cost more than it'd be worth...
the MR2 and Camry have TOTALLY different engines...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 06-26-2003, 09:25 AM   #3 (permalink)
Mighty Flying Family Sedn
View Mighty~Mart's Photo Gallery
would it be the same for the celi GTS?
Mart~
Camry Gen 5 SE
2.4L I4 DOHC
Stock 16's
Totally stock
Mighty~Mart is offline   Reply With Quote
Old 06-26-2003, 10:02 AM   #4 (permalink)
View soundlzrd's Photo Gallery
Re: Re: mr2 6spd sequential manual
But same trannys
soundlzrd is offline   Reply With Quote
Old 06-26-2003, 10:06 AM   #5 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
v6 camrys and mr2 turbos use the same a153 tranny ( as i was told by the wraith) not sure bout the mk3 mr2s though... might be a slight difference but if u've got the dough im sure u can do watever u want...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 06-26-2003, 04:29 PM   #6 (permalink)
Music nerd?
View Warped's Photo Gallery
Might be different because before the MR2's were using S-family engines, as was the Camry I4. But now, the MR-Spyders are using the ZZ-family engines...very different, arent they?
Warped is offline   Reply With Quote
Old 06-26-2003, 04:47 PM   #7 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
As long as the bell housing bolts up it should work. You will have to get custom axles made to fit the car along with custom mounts. Toyota's bell housing are the same for a lot of trannys. Like the RWD setups you can put the same tranny in about 4-6 different engine familys. So if you have a way to check the bell housings then that will be your anwser although if you have more dough then you can get a custom bell housing made to fit as well.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 06-26-2003, 11:31 PM   #8 (permalink)
I has boost..!
Razo-E's Avatar
Re: Re: Re: mr2 6spd sequential manual
Originally posted by soundlzrd
But same trannys
he's talking about the MKIII MR2 and the Gen.4 Camry...
the MR2 is RWD, but it's MR, so that means it has no drive shaft, the MR2 is basically a "backward" FF...
it might be possible...
but it would cost too much $$$, and probably not worth the cost...
Old 06-27-2003, 01:04 AM   #9 (permalink)
another idea
how about adding a sportshift option to my already automatic tranny? i've seen an avalon with this but cant find too much info about this mod
Old 06-27-2003, 02:04 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
e153. a = automatic.
"Skoolin' the unlearned!"
Old 06-27-2003, 02:06 AM   #11 (permalink)
Blazin...
ooopss.. sawee...
Neoscepter
Old 06-27-2003, 03:57 AM   #12 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
I dont think the e153 tranny ever came in a automatic most automatic are C series.
The 6speed off the celica is already weak ass it is why mate it to a very torque motor??? My friend has already gone thru 2 trannies in his GTS ... As for the sequential shift kit... try Level10 they had a shift kit which allowed you to manually shift the automatic tranny...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
