steering vibrate? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2003, 12:38 AM   #1 (permalink)
View bigsea54's Photo Gallery
steering vibrate?
My V6 camry vibrated stongly before I balanced and align the tire and the wheel.
But in 70 mph, the steering still shake a little bit, not very strongly, but annoy me. Is it normal?
Thx
bigsea54 is offline   Reply With Quote
Old 06-28-2003, 03:47 AM   #2 (permalink)
Official TN Rice Hater
97KaMuRi's Avatar
View 97KaMuRi's Photo Gallery
You need an alignment on your tires. Once you do that you wont have any more vibrations.
97KaMuRi is offline   Reply With Quote
Old 06-28-2003, 01:25 PM   #3 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
balancing the tires usually does the job.
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 06-28-2003, 02:31 PM   #4 (permalink)
THank you for the replies.
I did alignment and balance, but still there are some vibrations. not strongly, but if I drive for several hours, it will tire me.
Old 06-28-2003, 08:39 PM   #5 (permalink)
Oomp loompa doopidy doo..
spills1969's Avatar
View spills1969's Photo Gallery
Hey man, I had the same problem in my 88 cam. only thing is mine was pretty much all the time. But if its the same thing, it might be your wheel bearing. Does it vibrate more when you turn either way? If it does, it may be your wheel bearing. if it aint that, it may be a loose steering knuckle bolt or something like that. I had that problem on my four wheeler!
http://www.cardomain.com/id/manwhorecamry
Nitrous is like a hot woman with STDs. You wanna hit it, but you're scared of the consequences...
spills1969 is offline   Reply With Quote
Old 06-28-2003, 11:27 PM   #6 (permalink)
97KaMuRi's Avatar
that or might be a your cv axles are bad.
Old 06-29-2003, 01:48 PM   #7 (permalink)
View mclee45's Photo Gallery
check if all your lug nuts are tight
mclee45 is offline   Reply With Quote
Old 06-29-2003, 02:38 PM   #8 (permalink)
yo i have 3 toyota's
aladdin102's Avatar
View aladdin102's Photo Gallery
how come my steering wheel vibrates when i play my sound system but doesnt shake when its off?
aladdin102 is offline   Reply With Quote
Old 06-29-2003, 04:12 PM   #9 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
either you got one bad-motha-fugggin' set-up and its rummmbling like hell! OR... try seeing (w/ your system off if it rumbles while you have it in park, compared to having it in drive, with your car not moving...) it is probably related to the amount of juice that you might be pulling...
Brandon
arcasmachineracing is offline   Reply With Quote
Old 06-29-2003, 06:39 PM   #10 (permalink)
View kocho's Photo Gallery
Re: steering vibrate?
Thx
Don't know what year you got, but my '00 has been vibrating for a long time. I recently got new rims and tires and was able to practically get rid of the vibration only after the third balance. The first two times they did a poor job. then I went to another place that did a much better job. As you say, I still have some vibration, but it is nothing like before. Try going to a place that does dynamic balance and will use a "road force" or "vibration control" machine that tests your tires for out of round as well as for balance. These cost more ($15-$20 per tire) but if this does not fix it, then you have other problems or the shop does not know how to use the machine or does not really care (which scary as it is might be the case in like 80% of the cases)
As someone else suggested, make sure your lug nuts are evenly torqued as well.
What brand of tires and rims do you have? Some tires/rims just don't balance well...
kocho is offline   Reply With Quote
Old 06-29-2003, 07:04 PM   #11 (permalink)
View Custmguru's Photo Gallery
have your rotors machined.
do you have vibration in the brake when you slow down too?
i had that problem in my S and i have the same deal in the wife's camry now...
i just bought new pads and ill have the rotors turned when i do it and ill let you know if it solves my problem
Custmguru is offline   Reply With Quote
Old 06-29-2003, 09:35 PM   #12 (permalink)
Re: Re: steering vibrate?
ThanK you all for the replies.
I bought the tires from Costco and they balanced the tires for me. The tires are Bridgestone Re950. After the first balance, I felt a little shake in highway at 70mph, so I went for a second balance, but not much improved.
Is it expensive for lug nuts check or other possibility check?
Nice to be a member here.
Old 06-29-2003, 10:25 PM   #13 (permalink)
spills1969's Avatar
ive never bought some, but as a matter of fact i was at wal mart today and i saw some in automotive. i think they were like 8 bux for a set
Old 06-29-2003, 11:01 PM   #14 (permalink)
Man on a mission...
I think he was being facetious Read his sig.
I got the same exact tires at Costco a few days ago too! Sweet deal, huh, with the $60 off the whole set. What size did you get? I'm enjoying mine, and they are replacing the shoddy 92's
Old 06-30-2003, 09:27 AM   #15 (permalink)
Re: Re: Re: steering vibrate?
Honestly, I gave-up hope for a perfect balance.
If they are nice, the'll torque the nuts for free. Just make sure they do not overtorque them (should be 76 lb/ft). Shouldn't make much of a difference but is one less thing to worry about.
A word of warning though. You might want to reconsider if it is worth it - I went this route myself with Sears/NTB. Since balance for life was free (part of the deal), I went there several times (more like 8-10 times over the life of the tires - at every 5-6K for rotation and balance and usually once more for them to re-do the balance...). Never could balance perfectly - some times better than others, but vibrations were there always. The result was that they stripped my lug bolts, because they torqued them too much (up to 100 lb/ft). I ended-up replacing all studs and lug nuts and this is not cheap, since I didn't want them to touch my car anymore (parts only from Toyota was about $100, replaced myself).
Basically, if you can't get good balance two-three times in a row without tire or wheel problems, change the shop give it another try then if it still does not work give-up, because it may end-up costing you more...
