Your new power steering belt may simply be too short. It wouldnt be the first time this happened to somebody - you may want to try a belt just a few millimeters longer. Even at the auto parts sometimes they do get it wrong! I have had this happen to me and i just found a belt that did fit at the auto parts.
There is nothing to it really, the only difference to any belt for any vehicle is
belt width,
belt depth (thickness)
and the length.
All these are important and can't be ignored because the belt has to fit properly in the pulley, as well as being of the right length! But two of the three you can determine more or less accurately just by looking and comparing. (Bear in mind that, unfortunately the old belt is no good for measuring length because it is stretched or broken but you can still use it for the other two factors involved).
The only limiting factor to how long the belt can be is, how far can you adjust it out to make it tight? If you get a longer belt and the PS pump swings all the way out and at the end of its travel and not tight enough, return this belt and get the next smaller one.
