Originally posted by spills1969
BTW: anyone else ever changed out a TC?
My buddy and I swapped the auto tranny on his 94 Camry (5S-FE) a few weeks ago.
Is it a LOT harder than a clutch, or about the same?
Having done both, i'd say about the same.
1. Drain the tranny.
2. Unbolt the axles from the differential.
3. Unbolt the access plate on the bottom of the tranny (its on the side of the tranny in between tranny and block). Its a little black metal cover held on with a couple small bolts.
4. Unbolt the torque converter from the flex plate. Theres 6 bolts on a 5S-FE, not sure about the 3S-FE. You need to spin the crank around so that you can remove all the bolts.
5. Unbolt the tranny from the block. Then seperate the 2.
When you reinstall the torque converter make sure you get that bitch all the way on. Otherwise it won't drive the pump and you'll fry the tranny. My buddy learned this the hard way.
