So I recently took it upon myself to do whatever I can to get my E-brake working.
I have I4 gen 3 with 4 wheel disc brakes and the parking brake drum thing.
I first adjusted the nut on the lever inside since it was the easiest to do. I tightened it all the way up and still nothing at the wheels when I would lift the lever, even though I was feeling resistance.
So next I took off the wheel and the little boot/cover to adjust the sprocket as per the manual. Thing is the sprocket is so rusted/stuck that even when I torque it hard with a thick screwdriver, I get nothing. I'm afraid of I try any harder I'll snap the screwdriver. I sprayed some liquid wrench in the whole and let it sit for a while, but still doesn't want to budge.
After that I thought I might just take off the caliper and rotor and see what I can see. Thing is that the top caliper nut also won't come off. I've tried alot of liquid wrench and hammering my wratchet, but nothing will get it loose.
So this leaves me kind of stuck.
Does anybody have any tips about getting this damn caliper off or about adjusting the sprocket through the rotor? Any tips would be greatly appreciated.
