Trader Rating: (
0)
New Window Problem
I have a Toyota Camry 2002,with
power windows. Problem is the windows on passenger side and both back windows don't respond to switches, whether from that door or from the driver's arm rest. There is no sound at all. I thought it might be the fuse, but the power lock on passenger side works, and I think one fuse governs both the window and lock. (At any rate I tried a new fuse, just in case. That wasn't the solution.) The window on the driver's door works as it should. Any ideas will be much apreciated.
Gene
