ECU reprograming - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-01-2003, 10:07 PM   #1 (permalink)
View draco12369's Photo Gallery
ECU reprograming
I was just wondering if anybody has reprogramed their stock ecu themselves, if so what is needed to do it and is it hard to do.
I dont suffer from insanity i enjoy every minute of it.
draco12369 is offline   Reply With Quote
Old 07-02-2003, 12:44 AM   #2 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
Re: ECU reprograming
You can't reprogram your ECU yourself. The only cars that I'm aware that you can do that is GM.
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 07-02-2003, 07:37 PM   #3 (permalink)
View levarg's Photo Gallery
you can get it reburn. any ase mechanic should able to do it
3VZ FE TURBO
levarg is offline   Reply With Quote
Old 07-02-2003, 08:34 PM   #4 (permalink)
ok does anybody know where i can get a programable ecu?
Old 07-02-2003, 09:16 PM   #5 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
try looking up TechTom if you have a 1997 and below car...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 03-04-2004, 09:08 AM   #6 (permalink)
View pichimr2's Photo Gallery
Talking
you can buy an programable electromotive tec 3 unit at paradise rascing the have some kits for the most popular toyota engines, an those are the most friendly and wide range unit i´ve ever used. i´ve been working with haltech and wolf ,also with power comander and tec 3 over run them all easy to install and program
honda eater
pichimr2 is offline   Reply With Quote
Old 03-04-2004, 12:29 PM   #7 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $307175
What do you have done to your engine that you need to reprogram your ecu? If you are still N/A, you won't seem much gains from it (maybe 5-10hp)...
If you really want to go to a stand-alone, you are looking at a lot of $$$ for the computer and the tuning... If you go with a piggy-back (S-AFC, ect.), it should be much cheaper...
-Charlie
Old 03-04-2004, 02:43 PM   #8 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
Tec 3 is a nice unit except the resolution isnt there... PLus their crank trigger is a joke, you dont need sooo many. I mean look at Toyota their crank trigger have only 4 four tooth and some of toyotas motors can spin to 11,000 rpm safely on them..
MySpace:
