Originally posted by spills1969
well maybe there was a misunderstanding, or bad wording on my part.
The topic (3S-FE -> 3S-GTE conversion) threw me off.
I thought you wanted to convert a 3S-FE to a 3S-GTE by swapping out the internals, head, etc...
I wanna keep my engine, 3SFE, but I wanna turbo it. Ive just heard that i shud get the 3SGTE internals when I rebuild it, instead of gettin OEM replacement parts for it. What cha think?
If your gunna rebuild thats the time to get better internals. Thats the way I look at it.
This is what i plan/planning to do:
-3SGTE turbo manifold
-turbo (not sure what to get yet)
-metal head gasket
-new pistons and rings
-rods?
If your getting a stock 3S-GTE turbo manifold the Toyota CT-26 turbo bolts right up to it.
For pistons, rings, and rods look in the group buy forum. JE forged pistons and Eagle billet rods for $700.
Im not sure if I wanna go as far as an IC, as much as I want to. I dont wanna put a WHOLE lot of money into this, but Im willing to put some into it. Right now, I dont wanna spend over 500, depending on how things go round here.
I hate to say it, but its gunna cost you alot more then $500.
So other than listed above, anything else id need to replace, or add onto it?
Rod bearings, main bearings, seals (front and rear main seal), gaskets, bolts (might want to look into ARP for head bolts / studs, rod bolts, and main bolts / studs), etc....
The other thing I suggest is a crankshaft from a 3S-GTE. If you get this along with the JE pistons & Eagle billet rods or stock 3S-GTE pistons & rods you'll have all forged internals.
Also have the head rebuilt.
