Sorry...I have like 3 questions in 1:
I have a 1999 Toyota Camry 2.2l I4 - Front Disk's Rear Drums
When I go over like dips in the road or the curb to my house, suspension squeeks; but it's only on bigger dips or doing like 1mph up the curb to my house. I believe that it's only on the front breaks though. I took it in to the mechanic and he said the the struts were a little squishy and would cost about $450 to fix (wasn't sure if he said each or total). He said they were not that bad and just drive on them until the get worse later on. The car does have alot of miles on it (~98K). So do you think I should get them fixed or just wait and do what he said and wait until later until later?
Also...If I press the brakes down they sqeak. I wont be moving (i.e. i am parked in my driveway) and they squeak when I press them down. If I pump the brakes in park they will squeak each time I push the pedal down. Should this be any cause for concern?
Last one:
My brakes squeak...a lot. It sounds like a bus sometimes. Like I just got them checked out from the same guy who checked my suspension and he said that they were like brand new and were like perfect. I never had new breaks on a car before that squeeked before. Just wondering if I maybe should go to a different place or will it eventually go away with normal wear and tear on the brakes?
TIA for reading my questions.
Edit: There is also a knocking coming from the front of my car when drive over bumps when I first start to drive. It goes away after I drive for a bit.
