Help! Check Engine Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2007, 05:53 PM   #1 (permalink)
View marniejc's Photo Gallery
Hi everyone,
I went and had my car worked on today, nothing major just oil change serp belt and brakes. NOWWW my check engine light is on. Mechanic said did I check my gas cap bc that may set it off. Ok checked it and its fine. I did notice that 2 screws are missing on the cover to the air filter.....do i need to worry? is there anything else I should be looking for?
thanks in advance
marniejc is offline   Reply With Quote
Old 03-30-2007, 09:23 PM   #2 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140695
screws shouldnt be missing. where did you have this work done? take it back and have them actually check to see what code is setting off the light. a loose or bad gas cap can set it off, but the code will tell you for sure what the problem is. though nothing they worked on would set off a code.
Old 03-31-2007, 03:09 PM   #3 (permalink)
A.J. Subramaniam
View s_ajanthan's Photo Gallery
camrys have this issue with the gas cap that every mechanic hears about on a daily basis. Not properly tighting it will lead to the check engine light. I get that once in a while on my 2001 and usually end up resetting it myself cuz the deal wants to charge me $60 for something I can do in 30 secs... damn dealers...
s_ajanthan is offline   Reply With Quote
Old 03-31-2007, 09:47 PM   #4 (permalink)
View marc780's Photo Gallery
We all know plenty of times when the Check Engine blinks on and it turns out to be for no reason at all. I bought a cheap mini-scanner device that reads any codes and then shuts off the CEL. I got it from harbor freight for $30 and it has already paid for itself more than once. But you do not even need one of these to put out the CEL. If you are pretty sure there is no real problem, just disconnect the battery for a minute or two and then reconnect the clamp. If the light goes out and stays out, problem solved!
Old 04-01-2007, 06:41 AM   #5 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
But when you do that, you lose all your presets and settings on the radio, clock resets, and the custom engine data gets reset, so it has to "learn" over again, which is why you see it idling alot higher after you remove the battery.
geoff5093 is offline   Reply With Quote
Old 04-01-2007, 01:36 PM   #6 (permalink)
Gameroom cash: $304255
"I bought a cheap mini-scanner device that reads any codes and then shuts off the CEL. I got it from harbor freight for $30"
Marc,
I paid $40 for that one from Harbor Freight when it was on sale. How did you get it for $30?
Mike
Old 04-02-2007, 11:23 PM   #7 (permalink)
Mike
I bought it about a year ago. Harbor freight makes a couple of them, that basically do the same thing. The style and brands change all the time at harbor freight, like every week. The answer is that you and i probably got different models that just do the same thing. I'd post a pic but they are not selling mine right now. It is just a little contraption about 6 inches long, with the OBD II plug and a tiny screen that blinks your codes 3 times and then clears the codes. Same thing only different. It was on sale that day, i was in the store so i snapped it up. Good thing too, i search their website and all they have to sell right now is the expensive one.
Old 04-03-2007, 07:03 AM   #8 (permalink)
geoff5093's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=94168
$39.99 - Looks pretty good for the price!
Old 04-03-2007, 12:43 PM   #9 (permalink)
Marc and Geoff,
The one I have is item number 46030. I paid $39.99 for it a couple of years ago when it was on sale.
Mike
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 10:00 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
