Requesting Bump Stop pics - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-06-2003, 08:27 PM   #1 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
Hey guys, I had three people (myself included) in my car and about 80 lbs of additional stuff in my Gen4 at first. I noticed that my rear tires were rubbing with every single bump in the road. I went ahead and take a brief look at the rear, and found that the round thing at the base of the spring/strut assembly awfully close to the tire. Is that normal?
I know my struts are going bad since I'm at 79K mi., but I just wanted to know if changing the struts will fix that problem. Thanks.
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 07-06-2003, 08:28 PM   #2 (permalink)
Man on a mission...
another shot of the rear, same side.
Old 07-06-2003, 08:30 PM   #3 (permalink)
Man on a mission...
went ahead and took a few shots of the front for comparison
Old 07-06-2003, 08:31 PM   #4 (permalink)
Man on a mission...
front again....
Old 07-06-2003, 10:08 PM   #5 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
I don't know if that's bad or not, but mine have the same indentations in them. I am interested in the answer to your question as well.
1991 Toyota Camry DX: Mods listed on Cardomain
http://www.cardomain.com/id/whitecamrydx
91camryDX is offline   Reply With Quote
Old 07-06-2003, 10:11 PM   #6 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
yes, that thing is normal, that's not what's hitting, it moves up with the tire, you're hitting your wheel well,
how many fingers gap is there back there unloaded? take the wheel off and inspect the top and bottom to look for broken coils
-Nick
Nick is offline   Reply With Quote
Old 07-06-2003, 10:12 PM   #7 (permalink)
View Deep's Photo Gallery
Are you talking about the spring perch? If so, it doesn't move independantly of the tire, its attached. If you go over a bump the perch moves at the same speed/rate/amount as the tire, they would never make contact.
Deep is offline   Reply With Quote
Old 07-06-2003, 10:41 PM   #8 (permalink)
Man on a mission...
I've got about 3 or 4 finger gap in the back.
Deep: I'm talking about the round thingy that the top of the measuring tape is touching in the third pic.
Old 07-06-2003, 10:44 PM   #9 (permalink)
Nick's Avatar
hmmm, then its not sagging that much, cuz my 92 camry, i had 4 ppl plus as much crap as you could fit in there and i had -1 inch gap and i wasn't hititng anything
but when a coil broke then i hit the wheel well a bunch
oh, and there is no way that thing that you're talking about could hit the tire, its just the support for the spring, its the top end that does all the travelling
-Nick
Old 07-06-2003, 10:51 PM   #10 (permalink)
Man on a mission...
So it sounds like new springs and struts will solve the problem, hopefully .
Old 07-06-2003, 10:54 PM   #11 (permalink)
Nick's Avatar
$$$$ rear springs are about 100$ for the pair, if you get knockoffs, like 200 for toyota,
-Nick
Old 07-06-2003, 11:23 PM   #12 (permalink)
Man on a mission...
My TRD & Tokicos are sitting in my garage. I'm waiting for those front strut mounts to come in this week
Old 07-06-2003, 11:24 PM   #13 (permalink)
Nick's Avatar
/me shakes his fist at you
i want some damn it!
-Nick
Old 07-07-2003, 01:36 AM   #14 (permalink)
rayray's Avatar
View rayray's Photo Gallery
do you have aftermarket wheels on your car? what is the size and offset of your rims? what size tire are you running on them? wrong sizing can lead to rubbing.
-rayray
rayray is offline   Reply With Quote
Old 07-07-2003, 09:26 AM   #15 (permalink)
View kocho's Photo Gallery
This will fix it if you have the correct rim/tire combo - my TRD/Tokico setup is much more resilient to the car bottoming-out compared to the stock. It's a great ride IMO.
About the rubbing, the thing that you show on your picture does not move relative to the tire/wheel. Your tires rub the fender most likely. If they are too wide or the wheels have incorrect offset this might happen.
With stock tires/rims even at full compression you should not have rubbing.
kocho is offline   Reply With Quote
