Hi,
i recently discovered that my inner door latch stopped working, so i have to roll down the window and open from outside.
i removed the door panel followed the intructions i found here, thanks to TN and everyone.
But here's my question:
I discovered that the cable was snapped into two pieces at where i circled in the first picture.
So i tried to order parts from autopartspeople.com .
1. should i order lock cable left for front door?
2. Do i need to order the plastic rod (circled in next pic) or does it come with the cable?
3. how do i connect the plastic rod onto the cable? is it just as simple as plug it in?
4. how do you get the old cable out of the lock assembly from the bottom pic? Is it hard to get access to?
5. What are the tools that i will need besides screwdrivers? Is there anything else i would need
Thanks everyone!
