its not hard. you will need a torx driver i forget which size. torx is the one that looks like the asteriks * by the way, in case you didnt know. you need to take the front dash panel off, first the stereo bezel, then there are 2 screws behind that, then 2 or 3 i forget about the inst. cluster. then i think thats it. i havent done it in like half a year. then you just pop it off and then there are 2 or 4 screws that hold the instrument cluster in. take that off then there are a bunch of screws on the back of it you need to take off. then the front comes off some how, then you will pop the needles off, then switch the black background for the new one, find someplace for power, ground and a switch location. put it all back together and you should be up and runnin. i could be a little fuzzy on this, ive never actually done it, i just know the basic principles.
-dave
