Painted intake manifold and valve cover - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-08-2003, 07:49 PM   #1 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Well I was bored this morning, so I painted my intake manifold and valve cover.
I also sanded off some of the rough edges (from the casting) on the intake manifold with a dremel.
I used Dupli-Color engine enamel (500 degree). Dark ford blue and clearcoat.
More pics at link below:
http://www.imagestation.com/album/?id=4289725501
"Skoolin' the unlearned!"
Old 07-08-2003, 08:21 PM   #2 (permalink)
rayray's Avatar
View rayray's Photo Gallery
looks good. nice job taping off the areas.
-rayray
btw: remove the ".orig.jpg" off the above IMG when you tyr and link a pic from ImageStation.
rayray is offline   Reply With Quote
Old 07-08-2003, 08:50 PM   #3 (permalink)
View warlock's Photo Gallery
look bad ass you taped off all the right places
warlock is offline   Reply With Quote
Old 07-08-2003, 09:06 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Thanks.
I fixed the link to the picture.
I forgot to say that I was tempted to bust out the air die grinder to port the intake manifold. Unfortunately the only way to port the entire runner is to cut the manifold apart then weld it back together or have it extrude honed.
Aluminum is a bitch to tig weld so I said screw it for now.
Old 07-08-2003, 10:43 PM   #5 (permalink)
Gen2 Camry
View 91camryDX's Photo Gallery
Nice job on the painting. Looks professional. I hate when people do things half ass to their car and you can tell they did. Glad to see you took your time and did it right.
1991 Toyota Camry DX: Mods listed on Cardomain
http://www.cardomain.com/id/whitecamrydx
91camryDX is offline   Reply With Quote
Old 07-09-2003, 01:17 AM   #6 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
You ever get the camry running again?
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 07-09-2003, 08:11 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
Not yet.
I found out what happened to the engine though. A part of the #4 piston melted.
Heres a pic:
Old 07-09-2003, 12:06 PM   #8 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Jesus Christ you got that mother hot as hell to melt that piston. Did you ever decide what you are going to do with your camry?
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 07-09-2003, 02:34 PM   #9 (permalink)
3s-fte power!
djprefix's Avatar
<------ notes to add more fuel to his setup.
Old 07-09-2003, 08:15 PM   #10 (permalink)
Originally posted by 88 LE
Not yet.
Heres a pic:
ddaammnn!!
Old 07-09-2003, 10:05 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
10psi boost.
Weird thing is that only #4 melted.
Compression check after engine blew showed:
#1: 185psi
#2: 80psi
#3: 185psi
#4: 20psi
My friend thought I blew a hole through the piston when I told him #4 was at 20psi.
JDM 3S-FE or full out 3S-GTE swap.
I really want to do a 3S-GTE swap, but another 3S-FE would be a whole lot easier and alot less money.
Old 07-10-2003, 12:49 AM   #12 (permalink)
OlDsChOoLeR
View FRITO's Photo Gallery
would that be a brand new jdm 3s-fe? how much would the engine cost? how much Hp also?
FRITO is offline   Reply With Quote
Old 07-10-2003, 01:02 AM   #13 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
is #4 the farthest away from the air/fuel flow? running lean, extra hot, and boost
happened to an old cherokee i rebuilt - the boost part
-Nick
Nick is offline   Reply With Quote
Old 07-10-2003, 01:44 AM   #14 (permalink)
3s-fte power!
djprefix's Avatar
Going to be building another turbo for the 3S-Fe if you get it? I still might have to sell my damn car, my mom's pushing hard again. So if you get a 3S-FE I'll have some parts to sell you
Old 07-10-2003, 06:21 AM   #15 (permalink)
Grenaded piston
88 LE's Avatar
Almost brand new. Engine has less then 35,000 miles.
I found one for $225 (on sale) from a local importer (Attarco Japanese Motors).
Nippon Motors wants $325. They said it would be about $470 shipped to my house. Their in So. Cal.
TAP Recycling wants $425, but its a US 3S-FE and it has at least 100,000 miles on it. So screw that. The only good thing about them is that their local (i'm about 25 minutes away from them).
http://www.nippon-motors.com/toyota.htm
Not quite sure on the hp. I do know that JDM motors in general burn cleaner and they have more power due to no smog equipment (egr).
