Steering rack - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2007, 01:09 AM   #1 (permalink)
View jasemc's Photo Gallery
Steering rack
Hi all
I have 2003 camry altise and it has a noise comming ftom the steering wheel. My garage thinks it might be the steering rack pinion seal? Is there any way to repair this without replacing the steering rack?
jasemc is offline   Reply With Quote
Old 04-10-2007, 08:11 PM   #2 (permalink)
View toyomoho's Photo Gallery
Changing the rack/pinion is time consuming/expensive. as such best run down all areas. The steering column, U-joint on steering shift (look under hood in back of engine/trans or the rack/pinion. Check Camry posts on this subject it has come up many times. Toyota also has a TSB on steering shaft noise.
Old 04-10-2007, 08:46 PM   #3 (permalink)
It looks like the noise is comming from under the bonet after where the steering shaft goes through the fire wall not right at the fire wall. There a joint that has a red ruber cover over it which you can lift up.and the noise is comming from under that. Sorry don't know techincal terms.
Old 04-21-2007, 11:20 PM   #4 (permalink)
View krgs4's Photo Gallery
if the noise is "sqeaking" when you turn
1. WD-40 or Lithium Spray $1.99
2. All purpose Japanese Automotive Grease $2.99 Tube
3. spay the WD40 into the shat area, where it penetrates the firewall
4. Greae the @@#$% out of the round rubber Seal area down there
the Sqeeky sound will disappear...done it on 3 Camrys...common Squeek.
*while you are at it grease all the door hinges...common sqeeks as well.
krgs4 is offline   Reply With Quote
Old 04-29-2007, 02:55 PM   #5 (permalink)
2004 Camry LE
somick's Avatar
Gameroom cash: $102015
View somick's Photo Gallery
There is a TSB for steering column noise. I think it covers vehicles from 2002 to 2006.
My 2004 LE was fixed yesterday for free.
I have 35,500 miles: 1,500 miles left for the warranty to expire.
I do not have TSB's number on me, but if somebody needs it, let me know and I will forward it to you.
Sam
2004 Toyota Camry LE
1999 Honda Accord LX
1992 Subaru Loyale
2010 Subaru Forester
somick is offline   Reply With Quote
Rack & pinion and 2 Axels Replaced! 73sport 3rd & 4th Generation (1992–1996 & 1997–2001) 16 07-18-2010 12:24 AM
94 Corolla power steering rack Toyota06 Archived Corolla threads 0 03-13-2006 03:02 PM
rack and pinoin steering nixmahn Camry & Solara Lounge 4 02-05-2006 06:50 PM
How to detach the steering rack from lower end of the steering column ruoknow Camry & Solara Lounge 4 10-28-2005 02:30 PM
Quoted for steering rack replacement _VVTi_ Camry & Solara Lounge 4 08-25-2005 02:15 AM
