From your pictures it looks like it is one of the mounting points from the air filter box itself which is broken. I dont see any need to replace this box just because of that broken mounting point, i'd repair it. If you replace it, it's probably a dealer-only part. So i'd just repair it.
From your pictures it looks like you could j.b. weld it together, (the best glue to use, nothing else works as well). It wont be pretty but will solve the problem, which is how to mount it back the way it was so vibration doesnt loosen anything.
I'd use a small piece of metal for a reinforcement, maybe now's time to get a little creative. If you own a drill and hacksaw and vice, you could find a suitable piece of metal at home depot and easily fabricate something. Then clean the box with solvent so the jb weld will stick and piece it together. Price the box first, my idea might look pretty good after you see what its gonna cost you for a new one.
If you live near a pick-your-part type junkyard a replacement box would be a lot cheaper though.
