I have a few questions left regarding the 5sgte setup.
1. I am going to run the 5sgte motor and turbo it eventually if not from the beginning. What turbo do you guys think would be good? Since the displacement will still be 2.2 liters and will be full of torque, I was thinking of one that spooled up at 3500-4000 RPM? Good or bad?
2. What size injectors should I run with this setup?
3. What do you guys recommend in terms of valve springs and a head gasket?
4. Should I port the intake manifold and throttle body, or is there an aftermarket one that will run with this setup, or just leave it be?
5. Last but not least- does anyone know of a good place to get your ecu reprogramed? I'm not talking about the pos that doesn't work like jet, or any ebay pos. I need a good reliable place especially since the redline will be 7000-8000 RPM and for other reasons. I live in the sacramento california, so and places around this area would be great but if not its cool. Any help would be appreciated!
Thanks,
Scott
