Does the CEL light have to be reset after a repair? (’98 LE V6 dead follow up). - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2007, 07:01 AM   #1 (permalink)
View Neo Fender's Photo Gallery
This is a follow up to my original thread: http://www.toyotanation.com/forum/t189485.html
The starting problem went away (mostly). Anyway, the code was “P0402 – EGR flow excessive”. I replaced the EGR valve yesterday. The code is still there. Does the CEL have to be cleared or should it have gone away if the EGR valve was the problem?
Thanks,
Neo Fender is offline   Reply With Quote
Old 04-30-2007, 11:24 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
if the egr valve was the problem, the cel should have gone away
but you can try resetting it anyway though- no harm in that
HaHa
Old 05-06-2007, 08:26 AM   #3 (permalink)
View marc780's Photo Gallery
You can shut off the CEL easily. Disconnect the neg battery clamp and remove it for a minute or two. (You will have to reset your radio stations and the clock.) If your fix did indeed work, the CEL will go out and stay out.
reset procedure Service Maintenance Reminder Light Suikelley 2nd Generation (2004-2010) 1 08-18-2007 11:24 AM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
Corner Light on 95 Camry LE v6 sk8ersublime General Discussion 1 04-11-2005 10:53 PM
Check engine light codes? '00 LE V6 supraman215 Camry & Solara Lounge 1 07-26-2004 03:13 PM
