Camry V6 SuperCharged VS 04 Honda Accord V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-17-2003, 02:50 AM   #1 (permalink)
View TypeRex187's Photo Gallery
OK ppl i want all u guyz to speak the truth here.. With 26Gz....WHo will win in a race.. a Gen5 TOyota Camry V6 w/ TRD supercharger or a HOnda Accord V6 04' model (240hp). my friend bought himself a brand spanking new Accord for 26Gz and my other friend bought himself a 03 Camry Le V6 for 21Gz out the door.. and i dunno how it started but we started talking shit to each other saying whos car is better and i came in and said that with the extra 5Gz the camry could of gotten a TRD supercharger and spank the accord lefted and right...so am i wrong>>???
TypeRex187 is offline   Reply With Quote
Old 07-17-2003, 08:15 AM   #2 (permalink)
Prepare tortilla chips.
Daffunda's Avatar
View Daffunda's Photo Gallery
it depends. If the accord is an auto, then the performance is about the same, considering that you're talking about the VVTi. If Accord is a 6speed, then there is no chance, Accord beats Camry hands down. 0-60 time for Camry V6 VVT-i is about 7.8-7.9, (maybe faster with premium?) while the accord auto V6 is about 7.5-7.6. The 6speed is in the 6 second range though.
If you put a supercharger on it, then I guess it would beat an accord, but still not the 6speed.
Daffunda is offline   Reply With Quote
Old 07-17-2003, 12:31 PM   #3 (permalink)
aite thanks for the response
Old 07-17-2003, 05:19 PM   #4 (permalink)
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
Here's a non-scientific comparison point: a few years ago, I took a brief, and now deeply regretted detour into GM ownership. I had a factory supercharged Buick Regal GS. This car comes with a 4-spd auto (of course) and its version of the dinosaur pushrod 3.8L V-6 puts out 240 hp and 280 ft-lb of torque. The car is a couple hundred pounds heavier than either the Camry or the Accord. Also, the gearing strategy, incl the final drive, differs from the Japanese approach. All that said, this car did 0-60 in 6.5 seconds. Not bad for a lard-butt Buick. With the Camrys, the engine output is of course dependent upon how aggressively the owner sets it up. I suspect that a well-blown Camry with sticky tires is going to pose a real, perhaps unbeatable, challenge to an unblown V-6 Accord, even a 6-spd. Although the new Accord does make 240hp, it only generates 212 ft-lbs of torque, and at an absurdly high 5000 rpm peak. The current stock CAmry puts out 220 ft-lb, at 600 rpms lower. You can bet that the S/C version is going to be generating a lot more torque, and at much lower rpms. If such a car's power and torque approach, or even exceed the conservative Buick's, then with the lighter weight, you've got an Accord killer. Remember, it's the torque that shoots you off the line and wins acceleration contests.
ekpolk is offline   Reply With Quote
Old 07-17-2003, 05:42 PM   #5 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
The Honda needs the 6 speed to keep in its sweet spot but with F/I you are making *significant* torque from 3500 RPM up. That's why the Subbies and EVo's are so much more 'driveable' than the likes of the S2000 and the Toyota GTS. My bet is on the SC. If you can't find an SC VVTI V6 to do it send the honda over to Calgary next month and I will do it with my toyota SC I4 without VVTI.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 07-17-2003, 10:03 PM   #6 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
What about the Mazda 6? It'll beat anystock Accord or Camry.:p
VVT-i Owns is offline   Reply With Quote
Old 07-17-2003, 10:55 PM   #7 (permalink)
fungke's Avatar
View fungke's Photo Gallery
i am not too sure about that.
Mazda 6 i4:
160hp@6000rpm
155 torque
weight: 3042lbs
Camry i4:
157@5600rpm
162 torque
weight: 3142lbs
Accord i4:
160hp@5500rpm
161torque
weight: 3109 lbs
maybe all the info above is irrelevant since i am learning, but the way i see it, the camry and the 6 would be almost the same, where as the accord would have the upper hand. however, if you were comparing the V6s then i think the accord will kill everything again and the 6 will beat the camry.
Mazda 6 v6:
220@6300rpm
192 torque
weight: 3243lbs
Camry v6:
210@5600rpm
192 torque
weight: 3151lbs
Accord v6:
240hp@5500rpm
212torque
weight: 3360 lbs
correct me if i am wrong please.
fungke is offline   Reply With Quote
Old 07-18-2003, 07:55 PM   #8 (permalink)
Bollywood Boy
mrbacardi's Avatar
View mrbacardi's Photo Gallery
woah camry v6 is lighter than accord v6?!?!
Mr. DIY
mrbacardi is offline   Reply With Quote
Old 07-19-2003, 04:41 PM   #9 (permalink)
aznsclboi's Avatar
View aznsclboi's Photo Gallery
I was under the impression that the TRD supercharger doesn't fit on the 2002 V6 Camry. Are you talking about an aftermarket Supercharger?
aznsclboi is offline   Reply With Quote
Old 07-19-2003, 07:41 PM   #10 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
Theoretically the TRD supercharger will fit the v6s without with vvti. It won't work on the v6 with vvti though.
I say take the accord v6.
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 07-19-2003, 08:38 PM   #11 (permalink)
really?!....mmm so what years of the 1Mz-Fe motors that doesn't have VvT-i? and why wouldn't the supercharger work witht he VVt-i...?
Old 07-19-2003, 08:56 PM   #12 (permalink)
aznsclboi's Avatar
From my knowledge, about midyear in the 2003 Camry V6 series, the engine became a VVT-i. Before then, No VVT-I, I got my 2002 SE V6 before the change over… No VVT-I for me, but I held out hope that the TRD supercharger from the 2001 would work.
In theory, they should be totally compatible, as the 1MZ-FE engines are nearly identical except for the placement of a few things under the hood. For some reason, I don't know what, maybe someone on the forum can who is familiar with the 2001 Camry 1MZ-FE V6 and 2002 Camry 1MZ-FE V6 can tell us what the difference really is?
Strange thing, I talked to a person at Toyota of Seattle, my local dealer, about 4 months ago and the parts person told me that someone at TRD had a supercharger prototype for the 2002 Camry V6, I CANNOT confirm it, though if they did; I doubt they would produce it. The Non-VVT-i Gen5 Camry was only produced for one year, not enough market for it.
Old 07-19-2003, 09:13 PM   #13 (permalink)
3s-fte power!
djprefix's Avatar
I think they're talking about the one with vvti. They're making superchargers for all the vvti engines now like the 1zz-fe. Hopefully it'll be as good as the one for the non vvti 1mzfe
Old 07-20-2003, 12:46 AM   #14 (permalink)
fungke's Avatar
any idea how much it would probably cost for the VVT-i version?
to my understanding...the VVT-i version is about $600 correct?
Old 07-20-2003, 12:56 AM   #15 (permalink)
3s-fte power!
djprefix's Avatar
There is no vvti version. According to the other post they're prototyping one. A 1mz-fe supercharger now costs more than 2k, so don't expect a cheap product.
