heres your instructions written by... ME
Have your window about half way down...
1. Remove door trim...
- 1 cover, two screws in arm rest/grip
- 1 cover, 1 screw under arm rest/grip
- two screws on the bottom under the door
- two pop in fasteners on the end of the door where the latch is
- two covers and screws near hinge side of door
- trim around door handle, use a flathead screwdriver, pry down on the bottom under the hinge and on the top above the hinge pry upwards. then pull the handle and slade the trim towards the rear.
- unplug the harness from the electric window/door lock switch
2. get some of that plastic out of the way that covers the door...
3. remove the 2? screws on the window, that holds the window glass to the regulator.
4. remove the 3 bolts or nuts that hold the regulator to the door body (you may have to remove the crossbar in the door, i can't remember.)
5. unplug and remove the old regulator and install the new one.
6. install the 3 bolts or nuts back on the regulator
7. attach the glass
8. fix the plastic, stick it back to the gooey black shit.
9. plug in the door lock / window switch.
10. put the damn door back on.
11. try it out and enjoy the SPEED in which the window goes up and down.
12. do not overuse the window regulator or let kids play with it up and down so as you do not have to replace it in the future!
thank you thank you folks, its been a pleasure!
GOODNIGHT!
