Steering Wheel Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-19-2003, 05:50 PM   #1 (permalink)
View Beng3102's Photo Gallery
Question Steering Wheel Help
Hey there to all, Thus anybody here know if they sell a Steering wheel hub for a toyota camry 99? If you have any idea feel free to drop a message.Thanks, o yeah i have a MOMO steering wheel if ever someone is asking what kind.
Beng3102 is offline   Reply With Quote
Old 07-20-2003, 01:43 AM   #2 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
im using the kit they use for the mk2 mr2 for my gen 3... im unsure of the fit to the gen 4 though but that's the best bet ...
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 07-21-2003, 11:59 PM   #3 (permalink)
Thanks
thank you for the reply. I will try to ask them if ever they have hub for MR2. if u have any question n if i can help just give me a halah at kalokwan@aol.com. thanks o yeah b4 i forget wat MR2 year are u tlking about? ok thank again.
Old 07-25-2003, 03:08 AM   #4 (permalink)
Blazin...
yeah using the mr2 mk2s not the aw11 use the one from sw20 but make sure u check the mountings for the gen 4 cos im not sure.. and if u want to make the horn work u gonna have to make ur own connectors to make it work hehee.. i had to do mine to make it work otherwise ur horn will be located elsewhere... good luck man...
Neoscepter
Old 07-25-2003, 06:25 AM   #5 (permalink)
Its still a Camry.
Camry_rider's Avatar
View Camry_rider's Photo Gallery
I don't recomend messing with your steering wheel unless you have the propper tools, and knowlage of airbags. Ive heard storys about people trying this, and ended up activating the air bag. Imagine a un-expected pillow of air shooting at you at 200 ft per second. OUCH! If I was you, Id confront your local Toyota dealer on this question.
1991 Lexus ES250, 2006 Nissan Altima 3.5 SE
Camry_rider is offline   Reply With Quote
Old 07-25-2003, 03:57 PM   #6 (permalink)
Blazin...
well for airbag safety it is very very recommended that the battery be switched off prior to removing ur steering wheel.. u will also need a steering wheel remover ( sort of like a reverse hammer also used for removing brakes that are jammed )
Neoscepter
