Gear Shift Lever is Locked - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2003, 02:41 AM   #1 (permalink)
View superdesi's Photo Gallery
My 2VZ-FE all of sudden does not go from "Park" to "Reverse" or "Drive" without pressing the manual override button.
When I push the lever button I hear a click coming from my brake pedal........but it will not shift and seems to have locked.
What could be the culprit?
superdesi is offline   Reply With Quote
Old 07-20-2003, 09:11 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
seems like the brakes applied sensor is toast
-Nick
Nick is offline   Reply With Quote
Old 07-20-2003, 11:19 AM   #3 (permalink)
(¬_¬)...
View Bensa's Photo Gallery
I had the same thing happen to my Gen3 V6 before... not entirely sure what I did but I think I opened the Centre Console /and or did something with the brake pedal area. It was the brake Solernoid or some part in there which engages the shiftlock mechanism. It wasn't an easy job as it was a very tight area and hard to see. Best to have someone hold a flashlight for you cuz it's a very small area to work with.
I think there was something in there that was a bit out of alignment or had a buildup of dirt/grime so I poke around and lube it with some WD40 and it's been fine ever since *knock on wood*
I remembered the frigging dealer wanted an insane amount of $$$ to do it and basically it was a DIY job.
Bensa is offline   Reply With Quote
Old 07-20-2003, 09:33 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
SAME exact thing happened to me too... only my reverse lights stopped working too...
first thing i tried was a new brake pedal switch. that didnt work, cause my original was fine. Then i determined that there was NO POWER going TO the switch. something got messed up in the wiring and that wire must have gotten apart. ANYWAYS, what i did was do MY OWN wiring of power to the switch, fused of course, you dont want to do anything without a fuse...
check that out and let us know how it goes.
-dave
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 07-20-2003, 09:41 PM   #5 (permalink)
I'm a Mac
zoni's Avatar
but before i figured all that out, I took the shift lock solenoid out and zip tied the locking level into place so it wouldnt lock ever... you can do that if fixing it doesnt work
Dave Zoni
Old 07-21-2003, 04:33 AM   #6 (permalink)
For now, I am just going to keep on using the override button until I can find some time to tinker with the center console.
I ordered an FSM........so that might shed some light on the wiring of that solenoid.
Thanks.
Old 07-21-2003, 09:56 AM   #7 (permalink)
I'm a Mac
zoni's Avatar
there are good diagrams for that system in the haynes manual. sometimes they suck, but in this case, they work
Dave Zoni
Old 07-21-2003, 03:59 PM   #8 (permalink)
View Custmguru's Photo Gallery
could be a fuse. i blew a fuse while putting in a stereo and it affected that also
Custmguru is offline   Reply With Quote
Old 07-21-2003, 09:15 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
its not a fuse if that is the only problem
make sure to check if the brake lights work with the brake
Dave Zoni
