Need help with strange electric problem
Hi there! I haven't posted here in a while now!
I have been having this problem with my Camry (1992 LE, 112,000 KM). Occasionally, when I slow down for a stop or a red light, my RPM go under the normal level they stay at (usually hangs around 1000 when idle or parked). They drop down to near 0 and, if I stay idle for too long, the car just turns off, and warning lights turn on in the dashboard. The car is then veeeery hard to start.
The problem gets weird because it is not constant. For example, it happens approximately once every 3 slowdowns for stop signs. Another important detail is that this used to happen all the time before, didnt do it a single time in the winter, and now it goes on again. The first time I noticed this was on a very rainy day, so my guess is it has something to do with humidity. At my local garage shop, they changed my spark plugs and (candles?) and it didn't fix the problem.
My way of fixing this is, when I slow down for a stop and notice my RPMs seem to be going too low, I go to neutral and give it a little bit of gas, to put the RPM up to 3000, then when it comes down, it stalls around 1000 like normally.
Anyway, if anyone can entice me into solutions, I haven't found anyone with a similar problem... Thank you for giving your advice/opinion!
