Help! Plasmacluster illumination? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2007, 08:13 AM   #1 (permalink)
View Wind Breaker's Photo Gallery
Japan Help! Plasmacluster illumination?
Last night, I drove our new TCH for the first time at night. With the running lights/headlamp switch in the off position, the plasmacluster backlighting is on.
When turning the running lights/headlamp switch to the 'auto' or 'on' position, the plasmacluster lighting & display backlighting goes off and I can't see any of the controls or temp settings. . .ls this normal? Do you all have to turn on the overhead light to see which button you're pushing or temp setting you're rolling the control too at night? ? ? ?
'07 Titanium TCH Nav Moonroof & Leather
Wind Breaker is offline   Reply With Quote
Old 05-25-2007, 08:38 AM   #2 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Does it go off or just dim? Because I know if it's getting dark out and you turn your lights on, it will dim the spedomete cluster, the clock, and the radio. I would assume it would also dim the plasmacluster, unless maybe theres something wrong with the bulbs or control, i'm not really sure.
geoff5093 is offline   Reply With Quote
Old 05-25-2007, 03:04 PM   #3 (permalink)
When I turn the lights to 'on' or 'auto', it goes off completely. . .I have to assume this is not normal, but would like to confirm before heading off to the dealership. Anyone else? ?
BTW, I've tried the brightness control.
On another note, we all wish there was more intelligence on the television, there's a control called 'brightness', but it don't work either. . .
Old 05-25-2007, 10:20 PM   #4 (permalink)
View Pipemajor's Photo Gallery
Ok, I've now had a chance to evaluate and properly record what happens with our TCH.
Daylight conditions:
ON ------ Climate backlight OFF
* -------- Climate backlight OFF
Auto ----- Climate backlight ON
DRL Off -- Climate backlight ON
Nighttime conditions:
ON ------ Climate backlight ON
* -------- Climate backlight ON
'10 TCH, Magnetic Grey Metallic, Moonroof, Heated Leather and NAV
'92 LE I4, 165k original miles, Silver Taupe Metallic, Moonroof, ABS
Pipemajor is offline   Reply With Quote
Old 06-03-2007, 05:45 PM   #5 (permalink)
Mistabullet's Avatar
View Mistabullet's Photo Gallery
Turn the odometer stick to the right. YOu can use this to adjust the brightness and even turn it off.
Mistabullet is offline   Reply With Quote
Retrofit Plasmacluster + NAV On LE? BenzML 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-23-2007 09:28 PM
Radio illumination out, all other interior fine. n1kki6 Camry & Solara Lounge 6 07-25-2006 08:36 PM
Illumination lights for the instrument panel don't work after stereo installation qwertvt Audio, Video, and Security - Tech 0 01-21-2006 10:57 PM
illumination wire? 95 COROLLA Archived Corolla threads 1 06-17-2005 10:43 PM
question on illumination wire tavalon Audio, Video, and Security - Tech 1 06-16-2003 05:13 PM
