swaps - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-24-2003, 09:53 PM   #1 (permalink)
View dirtysouthcamry's Photo Gallery
swaps
trying to make my 5s-fe into a turbo need info on the how too's also want to know if anyone has done the automatic convert to the 5 speed yet if anybody has any info on these mods please email me @dirtysouthcamry@yahoo.com also check out the pics i mad 20s fit on my 93
dirtysouthcamry is offline   Reply With Quote
Old 07-24-2003, 10:35 PM   #2 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
what pics
Fresco Bob is offline   Reply With Quote
Old 07-24-2003, 10:43 PM   #3 (permalink)
oh sorry you have to goto cardomain .com cause it says the pics are to big to put on here http://members.cardomain.com/dirtysouthcamry
Old 07-25-2003, 02:31 PM   #4 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
TRD Northwest has a 5SFE turbo kit that gives you a safe 5psi for a factory spec engine. Anything higher, I would recommend you rebuilding your bottom end with (at least) forged pistons. Getting good connecting rods would be beneficial also.
Regarding the tranny swap, you will need a flywheel, clutch reservoir, & pedal. I would also get new 5-sp tranny mounts too.
I would highly recommend investing in a new clutch and throwout bearing, as well as a clutch alignment tool to make sure everything is lined up when you slide the tranny in.
Good luck.
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 07-25-2003, 02:35 PM   #5 (permalink)
View 2drcam's Photo Gallery
Post
here's an excellent tutorial on the tranny swap
http://www.tt-cc.com/ratko/swap/
2drcam is offline   Reply With Quote
Old 07-25-2003, 03:05 PM   #6 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
those actually look really good... what kind of wheels are they?
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 07-26-2003, 05:54 AM   #7 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
talk about the need for a search function... oh yeah there is a search function... USE IT!!!
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 07-27-2003, 06:12 AM   #8 (permalink)
Scuzzle-butt
xavior66's Avatar
View xavior66's Photo Gallery
Wow, I'm really liking that gen. 3! Nice and clean.
It's not what car you have, it's what you do with it that matters.
Packing your lunch in a paper bag-$5.00
Eating your lunch you bought on an airplane-$50.00
Losing your lunch from the airplane's cuisine, but not having a paper bag-Priceless
For everything else, there's paper bags!
xavior66 is offline   Reply With Quote
Old 07-27-2003, 01:33 PM   #9 (permalink)
I'm a Mac
zoni's Avatar
Im really liking that quote, excellent!
Dave Zoni
Old 07-28-2003, 10:26 AM   #10 (permalink)
they are icon rims made by apc i went throught a lot of trouble finding the right offset all the name brand 20's wouldn't tuck so i had to go with these i like thought but the info on the trany swap is for a v6 mine is a 4 cylinder i know the parts are gonna be different but will it still be the same stuff just for the 4 cyl. how difficult was it im in automotive school and plan to do the turbo stuff and the tranny stuff my self thanks for all the help
Old 07-28-2003, 04:39 PM   #11 (permalink)
I'm a Mac
zoni's Avatar
how about some PERIODS once in a while!
what size are the rims?
Ratko's 5speed conversion is almost the same for 4cyl, just different tranny and clutch and i advise getting the manual ECU vs. modifying your existing ECU.
You could put a good turbo kit together cheap. Use used parts. ct-26 turbo and turbo manifold from an MR2, custom uppipe and downpipe. beef up the exhaust. Injectors from a supra, new fuel pump, or supra pump. you will need to move your oil filter, pipe the oil lines, tap the oil pan, not to mention all the intake and exhaust piping that needs to be bent specifically to fit the car. A good muffler shop would be able to do all of that though.
Just read up on turbo installation, turbo mechanics, different turbo setups, gather all the info you can and make a good list of what you need. Then you will realize it will cost about 3000-3500 just for parts to do the tranny and turbo.
Dave Zoni
Old 07-28-2003, 05:01 PM   #12 (permalink)
menaboy64's Avatar
View menaboy64's Photo Gallery
holy shiat bro, is the turbo kit so you can help move the 20's? thats alot for a 4 cyl to lug around.
www.craptoons.com Oh it's true, it's damn true!
menaboy64 is offline   Reply With Quote
Old 07-29-2003, 10:07 AM   #13 (permalink)
sorry zion. OK the rims are 20x8.5 with a 38mm offset i think, not sure about the offset. i just bought the ct-26 turbo and exhaust manifold off ebay. and i just called a junk yard and went over the parts list from the thread article above and its only going to cost me about 575 for all the parts so thats alot cheaper than his v6 conversion.
Old 07-29-2003, 10:08 AM   #14 (permalink)
oops zoni
Old 07-29-2003, 11:50 AM   #15 (permalink)
toyrolla's Avatar
Exclamation
Ok...Ummmm....you're going to run a turbo with 20's wrapped in rubber band tires....
You're talking about a turbo setup with a Plus 4 wheel/tire upgrade.
To run a turbo setup, not only must you have a good contact patch on the ground, but you need to have some actual rubber on the ground.
Unless you want to be spending $$$ on tire (and possibly wheel replacements), I suggest you increase the meat on those tires by downgrading to a smaller size wheel.
Now, if you DO have $$$$ to blow on extra tires, then quickly include a set of Bridgestone Potenza S-03 Pole Position in a 205/50ZR16 size.....
....those will be for MY CAR!!!
:p :p :p
Thanks in advance for your unselfish generosity!
Regards,
Toyrolla
