ALL 3rd GEN OWNERS ATTENTION!!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2003, 06:00 AM   #1 (permalink)
Its still a Camry.
Camry_rider's Avatar
View Camry_rider's Photo Gallery
Exclamation ALL 3rd GEN OWNERS ATTENTION!!!!!!
The reason I've brought attention to this subject is a A/C Stereo conflict. Last night I was driving around, and all of the sudden I heard a cracking noise. I stopped and jumped into the back and poped out my power block fuse for my amp, thinking that ground crossed positive, this was not the case. I then fugured out that something had gone really wrong concerning my cd player, a 600$ unit at that. I only paid $200 for it....but still, it was "Teh Suk" Anyways, I turned off my cd player, and reset it. From my passenger side speakers out came a very loud screech, (sounded like a bottle rocket went off in my car. Then the speakers cracked as if they were blown, in fact they were. Minutes prior to the incident I was showing off my system, had it up to about 58 vol level out of 62, no distortion what so ever, sounded just as good as when I put it all in. What had happened with my deck was water from the A/C Vents conviently located and not propperly insulated above my CD Player (Thank you TOYOTA! *middle finger*) Anyways, water from the vents dripped down onto my cd player top, I turned a corner and all the water had drained into the head unit causing a short, which caused my speakers to blow out, when it shorted Im guessing it created a large wattage amount and surged through the lines causing only those two speakers to blow as well as messing up the right side of the cd out-put. All this was caused by a drop of water. I suggest you guys remove your cd players, and tape up the rear vents. This is where the water drips down. This has also happened in 2 other 92-96 Toyotas. Has this happened to anyone else?
1991 Lexus ES250, 2006 Nissan Altima 3.5 SE
Camry_rider is offline   Reply With Quote
Old 07-25-2003, 06:04 AM   #2 (permalink)
importfest's Avatar
View importfest's Photo Gallery
Omg guy that sux balls I cant believe that, it has never happened to me but i am going to check it out on mine.
back now, perfecting the new
importfest is offline   Reply With Quote
Old 07-25-2003, 06:22 AM   #3 (permalink)
Its still a Camry.
LOOK FOR WATER SPOTS ON YOU HEAD UNIT! My stock unit also had water spots and damage. Im using my stock 87 Celica am/fm tape player. I just rembered I can bypass my right channle by connecting my right lines to the left ones, I won't have balence.....But it beats the hell out of what I have now. Not to mention those 2 12 inch Audio Bahn 1000 watt subs can once again shake the earth!
Old 07-25-2003, 07:18 AM   #4 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Wow, this is teh first time Ive ever head of this happening.... must be some crazy humidity in FL!
Honestly though, thats a pretty extraordinary situation to the the least.
ratko.org
Ratko is offline   Reply With Quote
Old 07-25-2003, 12:04 PM   #5 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
not really, I get condensation on my vents and the surrounding areas in the summer time.
Thanks man! I'm gonna hook up some plastic in there asap!
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 07-25-2003, 12:23 PM   #6 (permalink)
Post Hoc Ergo Propter Hoc
Bishop13's Avatar
View Bishop13's Photo Gallery
Almost makes me glad my A/C doesn't work hehe...
Capitalization is the difference between helping your uncle Jack off a horse, and helping your uncle jack off a horse
1997 Toyota Camry LE / 2001 Land Rover Discovery II / 2006 Audi A4
http://www.flickr.com/photos/henryenriquez/
Bishop13 is offline   Reply With Quote
Old 07-25-2003, 12:44 PM   #7 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Oh poop man! Hopefully you can still make a false warranty claim with the deck maker. If not, luckily you only paid $200...still, that's $200 gone
I've never heard of this happening. Thanks for letting us know though
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 07-25-2003, 01:34 PM   #8 (permalink)
View warlock's Photo Gallery
thanks for letting use know,i never heard about that befor.
warlock is offline   Reply With Quote
Old 07-25-2003, 03:12 PM   #9 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i never use those vents anyways
-Nick
Nick is offline   Reply With Quote
Old 07-25-2003, 04:59 PM   #10 (permalink)
Bollywood Boy
mrbacardi's Avatar
View mrbacardi's Photo Gallery
i have a gen 3
but got no A/C
so you can all suck my dee
until i pee
so PEA-
CE
Mr. DIY
mrbacardi is offline   Reply With Quote
Old 07-25-2003, 05:31 PM   #11 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
Must fabricate stereo umbrella... becareful putting stuff above your stereo... it can cause the heat to stay in or near the stereo and not dissapate therefore making it prone to overheating. I'm not sure what can be done about this though. I supposed if you have a double din (like gen3 cams) you could put the Stereo into the bottom slot and the pocket above it, but from my experience you can't do it THAT easily. You'd have to drill some extra holes in that metal mounthing thing.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 07-25-2003, 08:19 PM   #12 (permalink)
A Poor College Student
The Wolf's Avatar
View The Wolf's Photo Gallery
That sux azz, man. Maybe that's what happened to my Pioneer several months ago. All of a sudden, it started blowing the radio/acc fuse in the box to the left of the steering column. Blew about 4 fuses, I took it back to Circuit City under the extended and had it sent off. They "found nothing wrong," but it's worked fine ever since. I hope the vents aren't the problem. However, I've driven 400 mile using the AC all the way without problems...
The Wolf is offline   Reply With Quote
Old 07-26-2003, 02:17 AM   #13 (permalink)
Its still a Camry.
The humidity here is un-godly. Yes its beautiful, and the weather is around 80 deg, but then bastard humity kicks into high gear and fucks it all up. I could fill buckets with sweat each day.
Old 07-26-2003, 05:44 AM   #14 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
theres a problem though, you cant just "tape up the vents". the vent tips come off with the dash trim piece. thats why they have that foam in there on the vents. if you dont, then that sucks for you cause you should have a piece of foam around the A/C vent holes when you take the trim piece off.then the vent ends go on over that and it forms a semi tight seal. i would say it is tight enough to keep water out of my system...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 07-27-2003, 06:02 AM   #15 (permalink)
jdv
Been there, and done it.
View jdv's Photo Gallery
never had that happen to me. even at 107% hummidity. never even had 'smoky' vents. perhaps something clogged in your system?
its real pita what happened to you. heat is evil.
3sge | 4 wheel steering | 4 wheel disk abs | full power | auto climate | auto headlights/wipers | adjustable suspension | ECT
no longer to my use... but still in the family.
http://www33.brinkster.com/gyrate/camry/default.htm
jdv is offline   Reply With Quote
