My Steering Wheel Farts! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-28-2003, 11:32 PM   #1 (permalink)
View prazeo's Photo Gallery
Angry My Steering Wheel Farts!
weird stuff. everytime i turn my steering wheel to the left, it makes this weird noise. it sounds like a mild fart or squeal or something. its kind of hard to explain. anybody know what's wrong with it?
and sometimes, at highway speeds, my steering wheel vibrates too.
any help would be appreciated. thanks in advance!
prazeo is offline   Reply With Quote
Old 07-29-2003, 12:22 AM   #2 (permalink)
Scuzzle-butt
xavior66's Avatar
View xavior66's Photo Gallery
From the way it sounds and the way I'm picturing it in my mind, it sounds like those "farts" might possibly be the rubber on the outer part of your steering wheel that's rubbing against the metal? Try taking off your steering wheel and see if you can find anything. (btw, you'll need a steering wheel puller to take off the steering wheel itself.)
It's not what car you have, it's what you do with it that matters.
Packing your lunch in a paper bag-$5.00
Eating your lunch you bought on an airplane-$50.00
Losing your lunch from the airplane's cuisine, but not having a paper bag-Priceless
For everything else, there's paper bags!
xavior66 is offline   Reply With Quote
Old 07-29-2003, 07:44 AM   #3 (permalink)
mox
God Machine
mox's Avatar
View mox's Photo Gallery
Or just pull very hard on your steering but take care to not break your seat at the impact of you returning into your seat after the steering finally get removed
That's how I proceeded for my steering and it worked fine
Don't forget to remove the connector for the airbag/cruise inside your steering.. if you forget it, you'll kill the coil that is used to transport 12V and airbag/horn/cruise to your steering
If you break it, I have a 4th Gen and 3rd Gen steering + coil here that are doing nothing
mox is offline   Reply With Quote
Old 07-29-2003, 08:29 AM   #4 (permalink)
View dj14901's Photo Gallery
Try this simple fix first...
First, before you go pulling your steering wheel, I had a similar problem. My steering wheel used to squeak when making shart turns at low speeds, and it drove me nuts. I lubricated everything around the steering wheel, but to no avail. Finally Gibson99 said to spray silicone spray where the steering shaft goes through the firewall (there's a rubber grommet there). After doing that, the noise disappeared. He said that it was a common problem with Camry's, so hopefully that's your issue...
Secondly, is your vibration at highway speeds only when you're braking? If so, there's a good chance that it's either your front rotors or rear drums that are causing the problem. Let me know if that's the case and I can post a test that'll let you know if it's the front or rear brakes that are causing the problem. If the vibration occurs when you're just cruising or coasting, it could be an alignment/wheel balance issue. Camry's seem to be more sensitive to the alignment/wheel balance issues than other cars...
HTH -
DJ
dj14901 is offline   Reply With Quote
Old 01-28-2005, 05:10 PM   #5 (permalink)
View DavePont's Photo Gallery
In my case...
I get kind of the same problems...
when mostly idle (like waiting for a red light to turn or at a stop) my steering wheel starts shaking hard (most of the time, not always). And that kind of plastic trim around the whole steering column (where the flasher, wiper and cruise-control levers come out from) has a broken clip on one side so it's kind of loose around the column, which amplifies the noise with a rather bothering rattle...
Also when I do sharp turns at low speed, it used to emit some "cracking" sounds... Twice I think.... like "scrack-scrack", depending on how fast I would make the wheel turn. But now there also is some squeaking added to it, right after each "crack", (making it "scrack-weei-scrack-weei" :P) which sounds like I drive a garbage can, even though it has only 67k KILOMETERS on it !!
And if dj14901 is right about the vibration being linked to a problem with the brake rotors, I have my rear brakes that make this greatly annoying squeal sound whenever I brake at low speeds. The pads are in good condition and I got the whole brake setup washed recently at a good mechanic's shop... So if this is of any help for you helping me, there it is lol!
THANKS FOR ANY HELP, REALLY APPRECIATED!
-Dave
DavePont is offline   Reply With Quote
Old 01-29-2005, 08:56 AM   #6 (permalink)
/bump
please help, this gets very annoying and I'm sure many of you could come up with an answer
Old 01-29-2005, 10:46 AM   #7 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Check your steering fluid, it sounds like a change is needed. Your fluid could be over or underfilled too.
Brake squeal means pads might be not reinstalled right or crap is in there or... list goes on forever. I think they sell some brake quiet down spray at some shops, give that a shot. A good mechanics shop can wash your brakes, but a great mechanic's shop would fix it if you brought it back.
amerikim is offline   Reply With Quote
Old 01-29-2005, 11:33 AM   #8 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
That would be because of a misaligned wheel or a wheel off balance. You better have a shop look at that.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-29-2005, 12:20 PM   #9 (permalink)
View bowlofturtle's Photo Gallery
i get that fart sound too only to the left at low speeds i said screw it i dont care. just crank up the music and go..
96 Camry Le I-4
bowlofturtle is offline   Reply With Quote
Old 01-29-2005, 12:48 PM   #10 (permalink)
klex's Avatar
View klex's Photo Gallery
you're not alone bro, my 99 le does that also!
klex is offline   Reply With Quote
Old 11-02-2005, 08:15 PM   #11 (permalink)
Toyota Fan
View Todd Soden's Photo Gallery
This is driving me nuts as well. I have tried White Grease, WD40 and Silicon spray and the noise keeps returning after a week or so. STUPID RUBBER ON RUBBER!
2000 Camry CE
2000 Echo
Todd Soden is offline   Reply With Quote
Old 11-02-2005, 09:06 PM   #12 (permalink)
View articledon's Photo Gallery
for you gen 5 camrys there is a TSB about a recall about the stearing wheel squeel. I think it is named st001 or something like that. It is sometype of lubrication problem. I took mine to the dealership a few months ago. the sqeeling stopped but now it is back as loud as ever
2003 LE 20% tint all around
Future plans: 18" rims, foglights,new stereo system
articledon is offline   Reply With Quote
Old 11-02-2005, 10:33 PM   #13 (permalink)
Midship Captain
ModifierMR's Avatar
Gameroom cash: $344471
View ModifierMR's Photo Gallery
my 03 camry makes a weird noise when i turn the wheel. it sounds like plastic squeek or something. It happens more often on Colder days. Sometimes in the summer but very seldom.
すべての日本への私のお悔やみ。
ModifierMR is offline   Reply With Quote
Old 11-02-2005, 11:41 PM   #14 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Is there a place to get the TSBs? I never ever go to the dealer, so there is no way for me to get notified. Unless they mail them, but I never got the one about the sulfer smell.
drunken_panda is offline   Reply With Quote
Old 11-02-2005, 11:45 PM   #15 (permalink)
View CX889's Photo Gallery
Same with 97' Camry. I got the same problem when I start my car cold. Sometimes it squeak too but I am not too concern with it. Maybe I will wait till I have some big maintenance.
2010 Venza V6 AWD / Magnetic Grey Metallic / Navi and JBL Package
CX889 is offline   Reply With Quote
