On most Camrys there is a stamped sheet metal splashs plate behind the brakes to keep the water off it. Maybe you bent this plate a little bit when you did the brakes and now its touching something when the wheels are on, that doesnt show when you are looking for it since you have taken the wheels off to inspect it -
qprint if a caliper drags, i'd rebuild or replace the calipers - although you may find it hard to find a rebuild kit anymore (even though the kit is nothing more than a few seals!).
I have had calipers seize up once or twice, often there is a pull and almost always the sticky caliper is much hotter than the other three, as you say. Also a good sign of a sticky caliper is that its lining is way more worn than the one on the other side.
I
dont think any grease is to go on this plate for the pads to slide on them, correct me if Im wrong.
Many mechanics do put high temp brake grease on the stamped steel pad mounting plates. High temp anti sieze is also fine.
But in actual practice it doesnt matter all that much whether you lube this area or not. Because any lubricant is quickly dirtied by brake pad dust anyway, thus negating some of the benefits of the lube.
Cylinder Slider Pin requires Lithium soap base glycol grease. What is this and where can I get it, or what is similar to this ?
You can find small packets of high temp-brake grease at the auto parts counter. Or better yet buy a tube of it, because there are dozens of uses for this grease. As before, high-temp anti sieze is also a good substitute as it clings tenaciously to the parts like nobody's business and takes a long time to wash or wear away.
Is the pad wear indicators supposed to face each other on each wheel ? [facing the rotor]
Yes, because here is how they work: The wear indicators are nothing more than a tab stamped onto the metal. When the pads wear too low, these tabs can then touch the rotor, and so they will make an annoying and obvious scraping sound whenever you apply the brakes. To let you know that the pads need changing now and maybe saving you a rotor or two.
