Hey guys...
I have been having this problem with "violent shifting" in my slushbox auto 94' i4 Camry... It is getting annoying, and I know that it can't be good for my transmission/car! Yesterday, I was just seeing if it did it in all gears, well, first gear it dosen't seem bad, seccond with the gas down some will kick and tuck/dive the nose down a little, (you know the feeling if you drive a manual and ya get crazy on that clutch
) and then shift abruptly, but when I let off on the gas as it reaches the "shift-point-rpms" and almost totally let off, it will shift much smoother. I had a disscussion with ChrisCorollaS about this topic, I initally thought that the violent-shifting might be due to the gasket in the tranny cavatating or something to that effect... but Chris explained that he thought changing my ATF would be a good place to start. I checked it the other day, and it could use a change, eventhough it is at proper operating levels... it has turned from the "bright red" to a light brown!
Do you guys think this would solve all muh worries???
I took a look at my diffrent gen 3 manuals yesterday... it looks like it will be a little bit of a task to change... do you guys think my small ass will be able to fit underneath my car w/o jackstands? (I have no drop on the Cam as of now) How hard is it? Its their any special precautions I should take?
I had the gas on the floor yesterday, and it wouldn't even SHIFT untill I let off to about 60% to the ground.
Thanks for any help you guys can provide me!
