change refrirerant on camry1992 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2007, 11:51 AM   #1 (permalink)
View quangnguyen's Photo Gallery
USA change refrirerant on camry1992
Hey everyone, i need some helps. The air conditioning system of my camry 1992 doesn't work any more. i want to use refrigerant R-134a, but don't know what i need to do. Give me some advices.
thank you so much
quangnguyen is offline   Reply With Quote
Old 06-28-2007, 02:26 PM   #2 (permalink)
ycartf's Avatar
View ycartf's Photo Gallery
If you can stay with the factory R12 I would do it. There are things in an R134 retrofit kit that do not always mix well with existing residues in the system (have to have all the old R12 purged) and may not work right with an R12 compressor/evaporator/etc. Nothing cools like R12 and if you can stick with it I would.
Tracy Faulkner
ycartf is offline   Reply With Quote
Old 07-04-2007, 11:23 AM   #3 (permalink)
rusty9's Avatar
Gameroom cash: $441505
View rusty9's Photo Gallery
i dont believe you can even buy r12 anymore. however they do make a reasonable substitute called Autofrost that may be cheaper than a complete r134 retrofit. First you should find the cause of your AC not working, be it a blown fuse or a leak that let out the refridgerant in the first place...because buying a couple cans of the stuff to recharge the system would be a waste of money if its just going to leak out in a day or two.
rusty9 is offline   Reply With Quote
Old 07-05-2007, 06:38 AM   #4 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
OP,
Before you attempt to add or change the refrigerant, verify that the cause of your problem is not something else such as a bad fuse, bad clutch on the compressor , or a broken or disconnected wire.
DFBonnett is offline   Reply With Quote
Old 07-09-2007, 12:23 PM   #5 (permalink)
I tried to find air conditioning fuse, but I only saw A/C relay. I don't know where it is. please help.
Thanks.
*DIY* Stock Stereo LED color change - (Lots of PICS) - 56k no way SnakeyeS Camry & Solara Lounge 56 12-09-2010 02:51 AM
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
My Engine Oil & ATF Change routine modestobulldog Archived Corolla threads 10 01-31-2007 07:29 AM
How often do you change your engine oil? solidg Camry & Solara Lounge 88 01-11-2006 10:12 PM
About to change my oil on my new camry,what type oil to change it to?high mileage cam Whitecamryghost Camry & Solara Lounge 9 09-25-2005 11:36 PM
