96 Camry Starting Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2007, 02:23 PM   #1 (permalink)
View toyteam's Photo Gallery
I am currently having an intermittent problem starting my 1996 Camry (2.2 automatic). It seems that when I try and start the car it will just make a humming sound (not a click) and won't start. If I turn off the ignition and re-try starting the car it will start, although it may take several attempts. Recently the problem has gotten worse. I checked the battery and it is holding a charge. I have also cleaned the terminals. Has anyone had this problem or might know what the problem is? Thanks for you the help.
toyteam is offline   Reply With Quote
Old 07-04-2007, 04:56 PM   #2 (permalink)
View marc780's Photo Gallery
If you are certain the battery is good, there's two main components to look at that can be causing this problem: starter and ignition switch. Starter or ignition switch, or both, could be worn out and only intermittently passing current to the solenoid and starter.
07 Camry SE V6 Problem - Service Dept. Stumped - Comments? kkmatuse 5th & 6th Generation (2002-2006 & 2007-2011) 61 06-27-2009 01:45 AM
92 Camry Starting Problem after rain TRKKID 3rd & 4th Generation (1992–1996 & 1997–2001) 9 10-18-2006 12:24 PM
94 Camry problem starting taovan 3rd & 4th Generation (1992–1996 & 1997–2001) 2 05-31-2006 10:11 PM
96 Camry Starting problem b_azadeh 3rd & 4th Generation (1992–1996 & 1997–2001) 10 01-08-2005 12:37 AM
96 Camry: sunroof and reading light problem Newbie Hardcore Tech and Competition 1 10-09-2002 10:12 AM
