Air condition of camry 1993 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-04-2007, 01:52 AM   #1 (permalink)
View quangnguyen's Photo Gallery
when I press the A/C switch, there is no sign of air conditioning system although air still flows from air windows. Please show me main possible causes.
Thank you so much!
quangnguyen is offline   Reply With Quote
Old 07-04-2007, 07:09 AM   #2 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
fuse
low freon
bad clutch
bad switch
disconnected wire to clutch
DFBonnett is offline   Reply With Quote
Old 07-04-2007, 11:52 AM   #3 (permalink)
View marc780's Photo Gallery
Dfbonnet has posted the main reasons, if i can add my two cents to it, i'd start with the basics, easy stuff first. Check the belt, maybe it is slipping badly or loose. If the belt is ok and the pulley is turning, look at your a/c switch, does it light up when you try to turn it on? If it doesn't, pop the switch for the a/c out of the dash and discconnect the contacts an connect them; in other words bypass the switch and see if you hear your a/c compressor go "click" and blow cool now. If bypassing the switch works, you know what to replace now.
If none of this makes any difference, put the switch back and assume it works for now. String a hot wire from the battery (splice in a fuse of the same amps) and run it to the compressor. You could use alligator clips or just crimp on a connector. Run the wire for the ground. If your compressor, refrigerant and pulleys ok, but there's some short in between the switch, you would now be blowing cold air.
Remember the A/C pulley is actually two pulleys, the outer one driven by the belt spins all the time the engine runs. The inner one only turns when you turn on the air - turning on the a/c switch on the dashboard engages its internal clutch so it too is driven by the belt - The inner one is what actually drives the a/c compressor. So if you crawl under and look, and have some one turn the air off and on, you ought to see the inner pulley engage and disengage with the action of the dashboard switch.
If the switch doesnt make the pulleys engage, and the inner pulley simply doesnt turn when it gets power, its possible that only the pulley is bad. You could change this on the car, without removing any a/c hoses - if clearance is too tight to get a puller in there, you could just remove all its bolts and pull it out from the engine for more room.
If everything above works, you probably have lost some refrigerant from a leak and you could try recharging it, before you bring it to the shop. You may have a bad compressor or a refrigerant leak that requires changing parts. And by the way - refrigerant doesnt wear out, (i'm a certified type 2 refrigerant holder) it leaks away from worn or broken parts.
Old 07-05-2007, 02:03 PM   #4 (permalink)
Thank you very very much for your help. I will test the power comes to air compressor and clutch. thanks again.
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Wow, I need help! please! Setheroo 89-95 Toyota Pickup/Hilux 7 06-05-2007 06:44 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Recharging a 1993 Camry Air Conditioner calguy99 3rd & 4th Generation (1992–1996 & 1997–2001) 4 08-11-2006 10:04 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
