Head Lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-03-2003, 08:34 PM   #1 (permalink)
dustin ricers and such
View CamrySleepsOnU's Photo Gallery
Head Lights
Any hints on how to remove the head lights?? I looked for screws and what not but i don't see myself getting them out without removing other stuff.
Also I have an intake on my camry, I'm thinking about inducing cold air on the intake with some PVC pipe and re-situating the battery. when my engine heats up so does the aluminum pipe for my intake and the air must then too. Just wonderin if ya'll think its worth it to get cool "fresh" air up there.
http://www.geocities.com/u_betta_b_flexible/1992_Camry_LE.html
1992 Camry LE 4cyl
Intake
Exhaust
cleared running/turn signal
JL 10w0's
Kenwood amps
Kenwood/Pioneer Hi's
Kenwood Head Unit
CamrySleepsOnU is offline   Reply With Quote
Old 08-03-2003, 09:58 PM   #2 (permalink)
H.I.D. Knut
View thisdj78's Photo Gallery
Hello,
Judging by these pictures here, there are two screws on the outer side of the headlamp and looks like the inner side clips into the grill......see for yourself, sometimes these pictures explain alot since you cant see in or under the lamp without taking it out.
there should be some folks here with the same year ride who've removed the headlamps.
thisdj78 is offline   Reply With Quote
Old 08-03-2003, 10:36 PM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
step 1 take off the corner light, need a phillips (star) screwdriver, there's a bracket that holds it in the engine compartment, unplug and put aside
2, remove front grill, again 2 screws one on each side
3, nut that was hidden by the corner light,
4, 2 nuts towards the middle of the car,
can't remember if there's another one towards the outside, then you just pull her out, minding the threads for the stud
-Nick
Nick is offline   Reply With Quote
Old 08-04-2003, 07:37 PM   #4 (permalink)
thanx
I removed the light and got that piping in woithout spending a time... i just used some old tubing from my old air boxes from old cars and i didn't need to resituate the battery. Also i convinced myself to buy clear corner lense off of ebay.
1992 Camry LE 4cyl
Intake
Exhaust
JL 10w0's
Kenwood amps
Kenwood Head Unit
