projector ish driving lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2003, 11:29 AM   #1 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
bought some, they're about 2.5 inch x 5 inch (friggin huge!!)
nowhere really to stick them, 2 options,
1 on either side of the front license plate (lower part)
2 inside the engine compartment behind the grill, possibly cutting out parts of the grill for proper fitment
suggestions? show me what you got...
-Nick
Nick is offline   Reply With Quote
Old 08-07-2003, 11:30 AM   #2 (permalink)
shuluke's Avatar
View shuluke's Photo Gallery
Pictures of what they look like? And what year is your camry?
Shuluke
1998 Camry (279,xxx miles)
2002 Camry LE (109,xxx miles)
2000 Solara (135,xxx miles) SOLD
2004 S2000 (98,xxx miles) Supercharged!
shuluke is offline   Reply With Quote
Old 08-07-2003, 11:36 AM   #3 (permalink)
Nick's Avatar
oh, yes, duh, its a 92
i can't find anything on the net about them, they're blazer diamond blue 9866, bought them off the surplus section of princess auto for 20$, they look kinda like this
like i said, 2.5 inch diameter, 5 inches long, uses a 894 bulb
probably won't mount them with the tape either, i'd like to be able to adjust them laterally
-Nick
Old 08-07-2003, 01:18 PM   #4 (permalink)
shuluke's Avatar
Next to the license plate sounds good. if you could put them in the grill with a stealth install though, then it would be tight. haha, i would flash cars every once in a while...
Shuluke
Old 08-07-2003, 03:01 PM   #5 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
heh! that shit is huge bro! dude if you molded them into your grille or something like that, they would look sweet I bet! heee hee, keep us updated!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 08-07-2003, 06:39 PM   #6 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
I'd say stick them into your headlights
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 08-07-2003, 09:48 PM   #7 (permalink)
Nick's Avatar
they're too cheap to stick in my headlights, plus they're only 37.5W
i'll install them when i get home from work, actually shit, i'll have to wait for crappy tire to open, unless i can make a little bracket from shit i can find at home
i'll put them behind the grill for now, if i get ambitious i'll cut out my grille
i'll just bolt them onto the existing holes in the top of the grille with a little bracket sticking back a bit
-Nick
Old 08-08-2003, 12:54 AM   #8 (permalink)
Nick's Avatar
damn it i know i've seen a few gen 3's with them in the front grille!!
-Nick
Old 08-08-2003, 01:15 AM   #9 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
you could probably mount them pretty low... where those little verticle supports are for the front bumper
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 08-08-2003, 01:18 AM   #10 (permalink)
Nick's Avatar
they barely fit in there, i'd have to swivel the support and they'll be sticking out, it'll look pretty dumb, plus i'd have to use the sticky tape, or drill through my bumper and even then i can't really get to the other side, cuz of the metal bumper under there
-Nick
Old 08-08-2003, 01:45 AM   #11 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
Scepter300RR has some in his grill, PM him to post some pics, or something...
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline   Reply With Quote
Old 08-08-2003, 02:17 AM   #12 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
wow ppl remember me here hehehehe
http://members.shaw.ca/hty500/photo.htm
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 08-08-2003, 02:27 AM   #13 (permalink)
Nick's Avatar
ok, so so far the plan is to cut out the middle part of the grill for about 2.5 inches, use a flat bracket at the top of the grill back a bit to hold the projector bracket
i'll cut her up in the morning. hopefully wont' fuck it up too much
-Nick
Old 08-08-2003, 06:12 PM   #14 (permalink)
Blazin...
u should mount at the bottom of the grill because the top part is soft... and doesnt provide good support.. u will have to remove ur horn to do this properly if u want it the same spot as where mine is... im currently using airhorn so i didnt need my stock horn there... also i didnt have to glue theparts i cut out i had to use a dremel to smoothen things over though... that's basically it.. good luck oldman...
Neoscepter
Old 08-08-2003, 06:54 PM   #15 (permalink)
Nick's Avatar
mounted from the top, boro bracket to bring them back, there will be a phase 2 to this, mounting them a bit more fwd in the grille,
they're right at the begining of the second section of the grille inways a bit, horn was moved down
the lights are too long to go in the sides without having to make a totally new bracket for them, that's step 2...
i'm sure i'll get bored this winter and bring my grille in to fiddle with it
-Nick
