Gen. 2 V6 gauge cluster question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-08-2003, 03:07 PM   #1 (permalink)
Scuzzle-butt
xavior66's Avatar
View xavior66's Photo Gallery
Well, I've always wanted the factory gauge cluster that had the tachometer in it for the 2nd gen. Camry. My 4 cylinder 3S-FE gen. 2 originally just came with the gas, temp. and speedometer. However, I was able to get a gauge cluster from a V6 automatic trans. gen. 2 Camry that had the factory tach in the gauge cluster.
Now then, onto the juicy stuff. I replaced my original gauge cluster with that of the V6 one. It all hooked up and it all lights up and works, but my question is, is it accurate?
I came across a post on the forums of SC3, and on there was a discussion about indiglo gauges fitting onto gen. 2 gauge clusters.
Then there was an interesting post that said this:
"yeah bout would it be easy to just grab a whole gauge assembly from a V6 model then buy indiglo's for it? it shouldnt be to hard to do, everythign should line up, and a tach just hooks up to teh distributer so, that shouldnt matter"
"Yeah, but it still wouldn't read right. People have tried it before and the speedo and tach were both off. I guess if you were desperate enough and didn't care what speed or rpm you were at, you could still do it. I just don't see why they don't make them for the 4 cyl camry's. All the manual and le 4 cyl camry's had tachs in them."
So with that said, does that mean that the tachometer from the V6 gauge cluster is giving inaccurate readings?
If so, then does anyone know where I can get a gen. 2 Camry gauge cluster for the 4 cylinder auto. that has the tachometer in it?
It's not what car you have, it's what you do with it that matters.
Packing your lunch in a paper bag-$5.00
Eating your lunch you bought on an airplane-$50.00
Losing your lunch from the airplane's cuisine, but not having a paper bag-Priceless
For everything else, there's paper bags!
xavior66 is offline   Reply With Quote
Old 08-08-2003, 03:52 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: Gen. 2 V6 gauge cluster question
The speedo and tach on the V6 is different.
Junkyard.
Procarparts has indiglo's for the 4 cyl. with no tach. If you want the tach piece you have to buy the indiglo's for the V6.
So in other words you need to buy 2 sets of indiglo's and mix and match parts.
"Skoolin' the unlearned!"
Old 08-08-2003, 03:54 PM   #3 (permalink)
OlDsChOoLeR
View FRITO's Photo Gallery
i would like to know also because this is a very near in the future mod for me.
everything just plugged right in like the stock one then?
i dont see why it would be accurate...
FRITO is offline   Reply With Quote
Old 08-08-2003, 04:22 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Yup it just plugs in.
The problem is using a V6 guage cluster on a I4. The speedo and tach on the V6 is different.
So if you have a I4 get the guage cluster from a I4 with a tach (LE model).
Old 08-08-2003, 04:45 PM   #5 (permalink)
Scuzzle-butt
xavior66's Avatar
Well I know stuff like the top speed and redline is different on the V6, but is the V6 tach. giving me inaccurate readings since it's being used on an I4? Just curious.
Old 08-08-2003, 11:14 PM   #6 (permalink)
View DIRTBIKEZ's Photo Gallery
Well what does it say when you are at idle?
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
DIRTBIKEZ is offline   Reply With Quote
Old 08-08-2003, 11:51 PM   #7 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Hi Xavior,
The reason why you're getting inaccurate readings on the speedo is because the V6 has a different tranny compared to the I4. As a result, the calibration between the I4 and V6 is obviously not the same.
Regarding the tach, I don't understand why that would be an issue; although, it is connected differently between the V6 and I4 models. Maybe the pinouts to the instrument panel differ somehow.
According to the wiring diagram, the tach on the V6 connects to the black lead of the igniter, as opposed to being connected off the distributor.
To troubleshoot this a bit further, you could eliminate the pinout connectors entirely by running a direct wire between the tach and the service connector (blue wire, green cap) off the distributor. See if it works from there when wired directly.
Then, try connecting the same direct wire to the black lead for YOUR igniter. See if the readings differ from when it's connected from the service connector of the distributor.
Just my .02, hoping that something helps.....
Good luck Xavior....
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 08-09-2003, 12:56 AM   #8 (permalink)
Scuzzle-butt
xavior66's Avatar
Ok, so here's the deal:
I used to have a Sunpro tachometer that I had hooked up to the Camry, but ever since I replaced the gauge gluster, I saw no more need for the Sunpro tach and just removed it entirely.
Well, earlier today I decided to hook back up the Sunpro tach and then compare readings, and this is what I got (by the way, I hooked one of the wires coming from the Sunpro tach to the distributor, the negative side in particular, or at least I think it was the negative side.)
Now then, I revved the engine, and the tach on the gauge cluster from the V6 read out approximately 2,500 rpm, while the Sunpro tach read out approximately 2,000 rpm. So there seemed to be roughly a 500 rpm difference between the 2. If this helps any, the redline for the I4 is around 6,000 rpm, while the V6 tach's redline is roughly at about 6,700 rpm.
So, anyone know which tachometer is giving me the correct reading?
Thanks so much fellow TNers for your time on helping another fellow TN lover out!
Old 08-09-2003, 02:34 AM   #9 (permalink)
toyrolla's Avatar
Question...
With the connections you stated, what are the readings from the 2 devices when the engine is at regular idle????
Regards,
Toyrolla
Old 08-09-2003, 02:09 PM   #10 (permalink)
Scuzzle-butt
xavior66's Avatar
Ok, so here's what I did:
I started the car and then went out for a 5 minute drive in order to get the car to normal operating temperature.
Then I came back home, parked the car, and then let it idle. The Sunpro tach read out approximately 750 rpm, and the V6 tach read out approximately 480 rpm.
But hey, I just thought of something. Dunno if this'll really make any kind of difference, but here goes:
Ok, my 1991 Camry was unfortunately the most absolute base model you can get. I soooooo wanted cruise control, so what I did was go to the local junkyard and got the cruise control computer, servo actuator assemply, wiring, cruise control button, cruise control gas pedal cable (the base model's gas pedal cable was somewhat longer than models equipped with cruise control)and cruise control steering wheel lever, and I hooked it all up.
Now it all works fine and dandy, however, when I went to replace the base model's gas pedal cable and hooked up the one for cruise control, I didn't adjust the slack in them according to factory specs. They're off, cuz the idle now is a little higher compared to when everything was adjusted right.
I thought I'd letcha know that too since that also can alter the rpm, obviously.
Now then, with all that info, is the Sunpro tach giving me correct rpm readings, or is the V6 tach giving me correct rpm readings?
Old 08-09-2003, 05:38 PM   #11 (permalink)
An idle of 650 +/- 50 rpm is nominal. Ditch the V6 cluster and get one from an I4.
'91 Camry DX
2.0L 3SFE Auto
R.I.P.
