Originally Posted by TypeRex187
Besides the way you drive also got to calculate your weight, i weight 225lbs and get around 24-26 mpg my younger brother is 150lb and he gets 28-31 mpg with the same car and same type of gas.
Don't forget to calculate the head winds as well, it might be a critical factor.
I had the car into Toyota today for Oil Change & tire rotation. I mentioned the losy city mileage & their sugestion was to let them keep the car for a couple of days & hook it up to the computer to see what is going on. I told them I was in the last year of my lease & when I have 2 months left on lease I will bring it in & see if they can correctthe problem, If they can I have the option of buying the car. I told them I would consider buying only if they can improve the gas mileage for the city driving.
You are unhappy with the gas mileage you are getting so like i said, maybe you should consider a Prius. Your gas mileage would probably double at least. Also it is almost as roomy inside as a Camry but not as much pep, i drive them all the time at work and they are ok. On long trips the shorter wheelbase might make the ride a little less enjoyable. But if i were you, i'd consider getting a Prius next time instead.
