1995 cannot pull codes Te1 to ground - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2007, 09:16 PM   #1 (permalink)
View actionpaintball's Photo Gallery
1995 V6 auto, CEL light on steady but runs, drives, idles fine. I get no blinks when TE1 is grounded.
I tried grounding the TE1 diagnostic port under the hood to E1; cel light did nothing but stay on. Went direct to ground and still nothing. I then pulled The ECU Battery Fuse and the check engine light did not clear...what I am doing wrong?
There is no test port labeled under the drivers side diagnostic port with a pin. (T, TE1. T1 or TE2 T2 ect...)
actionpaintball is offline   Reply With Quote
Old 07-31-2007, 03:41 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You need a scanner to pull the codes. Shorting TE1 & E1 on your engine (1MZ-FE) does not work.
"Skoolin' the unlearned!"
Old 07-31-2007, 06:36 PM   #3 (permalink)
View toyomoho's Photo Gallery
Try AutoZone to scan the codes.
engine/ABS light help.... trninhds Camry & Solara Lounge 11 06-17-2006 11:06 PM
tC ground clearance with ground effect kit P1no12 1st Generation (2005-2010) 2 04-27-2005 07:37 PM
How Do You Pull Codes? Deep Celica Forum 1 08-01-2003 12:21 AM
