Serp. belt squeaking loudly on 91 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-31-2007, 02:01 PM   #1 (permalink)
On my 4th Toyota!
View noodlesoup's Photo Gallery
What is the solution?
noodlesoup is offline   Reply With Quote
Old 07-31-2007, 06:15 PM   #2 (permalink)
View toyomoho's Photo Gallery
A belt is either too loose or something that it is driving has a bad bearing. Which belt, Alt and A/C or PS. There is an adjustment to tighten the Alt belt at the Alt mount. The unit is moved one way or the other in its mount to tighten or loosen the belt. The same for the PS pump.
The link below provides access to service manual info.
http://oregonstate.edu/~tongt/camry
Old 08-02-2007, 12:07 AM   #3 (permalink)
40x40 pixels is crap !
Velox_camry's Avatar
View Velox_camry's Photo Gallery
also try rubbing dry soap on the belt we used to do that on my friends old mustang. it made the squeaking go away. good luck.
"Guardrails...those things that separate the men from the boys."-Fumiaki Komatsu
Velox_camry is offline   Reply With Quote
Old 08-05-2007, 12:58 AM   #4 (permalink)
View Gopal's Photo Gallery
Check the harmonic balancer. I had to change mine recently (90LE, 140K). It was split at the joint. Lucky I caught it in time.
Gopal
Gopal is offline   Reply With Quote
Old 08-08-2007, 11:48 PM   #5 (permalink)
View marc780's Photo Gallery
The solution follows here. 1. Do NOT use belt dressing. It eats the rubber and then you will just be at 2) change the belt. 3) if the belt is good, use some silicone spray on it, or even armor all. 4) If it won't stop it, change belt.
(Did you have an accesory changed recently? One time i had Pep Morons change an alternator and they put one on that had a pulley too small. And what's more they stripped the clamp bolt. It took me months to figure this out. Take the high road though, just assume people are not idiots or just watch out for yourself.)
Timing Belt an issue on 91 Camry?? 89_3SFE 1st & 2nd Generation (1983–1986 & 1987-1991) 2 05-24-2006 11:32 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
2007 Camry Seat Belt Trunk Sunroof Problems. Rotten Eggs grosenbeck 5th & 6th Generation (2002-2006 & 2007-2011) 4 04-19-2006 10:17 PM
