What should I replace on a used engine while it is out of the car? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-11-2003, 11:31 AM   #1 (permalink)
View bennington28's Photo Gallery
I have a replacement engine hanging on the lift. I am going to change the timing belt, other belts, water pump.
I was thinking about changing the front and rear seals.
I could also tackle the head gasket and oil pump. If I take the head off, then I also could replace the rings, although I have never done that before.
What do you think?
It is a 80000mile 2.2l l4 from a 93 camry xle.
bennington28 is offline   Reply With Quote
Old 08-11-2003, 12:30 PM   #2 (permalink)
Un-Official TN dude
View TypeZer0's Photo Gallery
y not simply rebuild the whole engine with brand new performance parts? and maybe strengthen it to prepare it for forced induction and get a super- or turbocharger
TypeZer0 is offline   Reply With Quote
Old 08-11-2003, 01:11 PM   #3 (permalink)
I just want it to last another 100000miles. It is my winter car. When replacing rings do you "have to" hone the cylinder walls?
Old 08-11-2003, 01:54 PM   #4 (permalink)
3s-fte power!
djprefix's Avatar
View djprefix's Photo Gallery
Check to see if there's still cross-hatching. There was on mine after 300k miles, so there should still be on yours. If there is then you wont' need to hone it.
You should just go out and buy a a rebuild kit. If no then you should definatley replace valve guides, bearings and gaskets. Check to see if your cams are still at good height and width.
3S-FTE: 9.3:1 compression + 5psi = owns you!
djprefix is offline   Reply With Quote
Old 08-11-2003, 02:00 PM   #5 (permalink)
Do you know of any companies who sell good rebuild kits?
Old 08-11-2003, 02:09 PM   #6 (permalink)
View chris-k's Photo Gallery
If you're doing a ring job you're pretty much rebuilding the engine anyway. Bearing shells are cheap, and you should check them if you're tearing down.
As far as a hone, look at the cylinder walls - if you can still see the cross hatch pattern you might be OK. But if the walls are shiny then you'll definitely want to hone them to break the glaze, otherwise you'll be blowing all kinds of oil past the rings. Check your manuals, but a lot of times it's reccommended that if you remove the head, you replace the head bolts/studs & nuts. The're not that cheap, I don't think. The reason why is that to get the clamping force of the head against the block, the bolts are stretched (that's why the head needs to be torqued to a specific value).
How much do you know about this engine? How's the compression? For Toyota engines, 80K is not a whole lot, and if it has good compression and doesn't burn oil, you'll save yourself a lot of money and hassle if you just use it as is. That said, the front and especially rear crank seals might not be a bad idea if they're easy to get to. Any rubber/rubbery part should be looked ar, like cam cover gaskets, belts, etc. These will harden with heat and time and cause oil leaks or other sorts of trouble.
The first (so far) foray into engine rebuilding I'm doing is on an old MG. The engine is quite different, but the principles are the same. I decided to do the full rebuild to get some better performance out of the motor, including higer-copmression pistons, new rings, new bearings, reground cam, and better carbs.
http://mywebpages.comcast.net/kvcbk/engine.html
The 2VZ-FE in my Camry has 175K on it, and still gives about 175psi on all 6 cylinders. I just did a full tune-up and replaced the cam gaskets and sealihg washers on the hold-down nuts and spark plug tubes. Runs like a champ!
Hope this helps you make a decision.
-=Chris
-=Chris
'89 Camry DX V6 Wagon
'91 BMW 318is
'77 MG Midget
chris-k is offline   Reply With Quote
Old 08-11-2003, 06:57 PM   #7 (permalink)
that is good information. where did you get your MG rebuild materials?
Old 08-12-2003, 03:16 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Since your not rebuilding the engine for performance I would use Toyota rings and bearings (main and rod).
"Skoolin' the unlearned!"
Old 08-12-2003, 06:47 AM   #9 (permalink)
You can look here as well:
http://performancemotorcars.com/
I just bought a full set of KYB struts from them - their delivery was quick.
The MG and Triumph (since it's actually a Truimph motor) parts I got from several companies that specialize in classic British cars. Moss Motors being one, Spitbits, The Little British Car Co, and others.
-=Chris
'91 BMW 318is
'77 MG Midget
