i tried the rubbing compound stuff, made by turtlewax and was 1.99, it was the only rubbing compound stuff i saw and it was the only one that didn't say avoid plastic trim and stuff. i started on my driver side headlight and rubbed it for a good 10 minutes then i wiped away the excess. i started on the passenger side but a minute or two later, it started raining so i wiped off the excess adn went inside. later that nite, i was adjusting the height of my lowbeams and noticed the driver side was brighter on the wall than the passenger side. previously, both sides were of approximately equal brightness. gotta find some time to finish off the passenger side.
to take apart ur headlight assembly, take the whole assembly to ur ktichen, take otu the bulbs and stuff and bake it at 275degrees fahrenheit for 10 to 15 minutes and the glue will soften. just carefully pry it apart but remember the glue will be like melted cheese on a pizza. reheat it and push it back together and use the clips to squeeze the parts together
