Transmission Slips in Reverse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-07-2007, 12:57 PM   #1 (permalink)
View DeCeder's Photo Gallery
Hello All,
Just aquired a 1990 Camry, V6 with an automatic transmission that slips in reverse. Don't have any more detail than that.
Questions:
1. Are there any known problems that would explain this condition?
2. Can anyone recommend a diagnostic procedure?
Thanks,
Dave
DeCeder is offline   Reply With Quote
Old 08-08-2007, 08:30 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $261890
View Doctor J's Photo Gallery
Lost of reverse is caused by:
defective overdrive C0 clutch or defective direct clutch.
the first problem is corrected by removal of side transmission cover and changing the C0 clutch pack( the transmission stays in the car) the second problem requres the complete tear down and rebuild.
Many owneres of camrys with 541e transaxle had it repaired at about 130 kmi. These transaxles are too weak for the engine. Making them stronger will overload the front end.
Doctor J is offline   Reply With Quote
Old 08-09-2007, 02:09 PM   #3 (permalink)
Thanks Doc.
Is there a chance that a faulty solenoid valve might not allow correct pressure for proper clutch pack engagement
Old 08-10-2007, 06:04 PM   #4 (permalink)
Doctor J's Avatar
No, the line pressure is controlled by spring-loaded relief valve.
On 90 model the solenoids are controlling forward gears and converter lock-up
Old 08-12-2007, 01:49 PM   #5 (permalink)
Thanks again DJ.
You seem quite knowledgeable on the subject.
Do you know if a manual transmission would go into this car without any modifications. I know, of course, that it would need a petal, clucth, possible flywheel change, etc.
Thanks,
Dave
Old 08-12-2007, 04:53 PM   #6 (permalink)
Doctor J's Avatar
Some forum members did the swap, but I do not know details.
Recurring Problem with 1995 Lexus ES300 Transmission mpr2 General Lexus Discussion 5 12-30-2008 08:54 PM
Transmission Flush Scare 03ESimposter Camry & Solara Lounge 14 12-07-2004 01:19 AM
problem: camry slips in reverse vsixcamry Camry & Solara Lounge 3 10-12-2004 12:50 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
