problem with reverse light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-13-2007, 08:47 AM   #1 (permalink)
View jayjay86's Photo Gallery
3rd Generation problem with reverse light
whenever i hit the brakes whenever i'm driving, the reverse light on the dash comes on. right after i release the brakes, the reverse light switches back to the drive light. anyone know what the problem is???
jayjay86 is offline   Reply With Quote
Old 08-14-2007, 12:22 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
My first inclination is to ask if you have replaced any of the tail lamps just before this started? If so, maybe (I admit it's a big maybe) you put in one that fit the base but was incompatible with the system. Check the manual for the right type...
Second thought is that somewhere along the wire loom a wire for the reverse bulbs and a wire for the brake bulbs have chafed and shorted out. When you put on the brakes a jolt of current goes into the reverse wire and may light up the display. I would think that you could test that with a volt meter and or an ohm meter. By the way, when this happens can you have someone check to see if your reverse tail light bulb(s) come on? That might tell you some more.
Kep
Old 08-14-2007, 03:06 PM   #3 (permalink)
View Kingdom934's Photo Gallery
reverse lights on the dash? Not the 'rear reverse light'? The 'shifter' reverse indicator on the instrumental cluster/dash, right?
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 08-14-2007, 05:21 PM   #4 (permalink)
View toyomoho's Photo Gallery
The reverse indicator lamp in the console appears to be wired to the backup light circuit. There could be a cross connection between the brake circuit and backup circuit feeding power to the reverse indicator lamp. Check wiring.
Old 08-15-2007, 12:55 AM   #5 (permalink)
the reverse shifter light ion the dash is what i meant
Silverstar "Ultra" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 35 07-22-2007 11:55 AM
Brake Light Problem zootjeff 1st Generation (1995.5–2004) 2 01-21-2007 07:35 AM
Reverse Light Switch/Connection k21xfr Celica Forum 0 08-08-2006 05:00 AM
Reverse light madness! thaharlequin 3rd & 4th Generation (1992–1996 & 1997–2001) 3 07-18-2006 05:36 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
