DRL's and HID - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2003, 06:42 PM   #1 (permalink)
View Kyle's Photo Gallery
DRL's and HID
I have a gen5 (2002 to be exact) Camry and I was wondering; is it possible to have the DRL's *on* in conjunction with the low beam lights? I'm going for an effect similar to the Lexus GS (see attached pic). When I install HID lighting I would like to have the DRL's on with the HID's, for color contrast/safety purposes, and just because I think it would look cool. I realize that the light emitted from the GS is probably from a wedge bulb, but I would rather not drill holes in my headlight housing to hook up a street light kit. Any advice or input?
Kyle is offline   Reply With Quote
Old 08-18-2003, 07:00 PM   #2 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
I actually want to do that as well, but I haven't had the time to figure it out. I'm going for the same effect as my signature, but that's with the high beams on.
If I do figure it out, I'll let you know!
Silver Streak is offline   Reply With Quote
Old 08-19-2003, 01:26 AM   #3 (permalink)
I smell McNuggets
[SMAN]'s Avatar
iTrader Score: 7 reviews
View [SMAN]'s Photo Gallery
try finding the correct reisister, if u can drop the voltage enough u can half the bulb run at like 1/4 power and that will give the effect.
96 Camry I4 with evo kit and custom everything else.
2005 4runner Sport V6 - Stock
2004 Camry Solara SE V6 - My new baby
[SMAN] is offline   Reply With Quote
Old 08-19-2003, 02:18 AM   #4 (permalink)
Yeah, a resistor may be the only option. The only drawback to using a resistor is losing the high beam function.
Old 08-19-2003, 03:56 AM   #5 (permalink)
View woshiagni's Photo Gallery
Actually, by using relays and diodes in combination with your resistor idea, you will be able to keep your high beams.
Wire it up so that when you turn on your low beams, the relay will switch on power from the battery directly to your resistor pack. The diode will sit at the junction between your resistor pack and your existing high beam wiring.
Electrically speaking, what you want to accomplish is a pretty simple task, but I imagine you'll have more of a problem finding electronics with the correct tolerances to pass the kind of amperage that headlights require. For example, don't expect to use Radio Shack resistors, unless you've got a handful of them heatsinked and wired up in parallel (parallel? is that right?).
Good luck finding the right parts, post pics when you're done. =)
woshiagni is offline   Reply With Quote
Old 08-19-2003, 04:07 AM   #6 (permalink)
View 808Camry's Photo Gallery
Actually the GS look comes from a sepearte 194 bulb in the high beam housing. Just drill a 1/2 inch hole and stick a bulb and socket in there.
Ron
My Camry
Click here if you dare!
808Camry is offline   Reply With Quote
