Originally posted by CamrySleepsOnU
how do u relay it?
You need a 12V / 30A SPDT (single pole double throw) or SPST (single pole single throw) automotive relay. SPDT has 5 prongs (87, 87a, 85, 86, and 30) on it. SPST has 4 prongs on it (doesn't have 87a).
87: Wire to constant +12V
87a: Not used (no 87a on SPST)
85: +12V Trigger (parking light)
86: Ground
30: Output to foglights
85 and 86 can be swapped around if you want. Just don't wire both (ground and parking light wire) to the same prong.
The parking light wire (green) is at the bottom of the fuse box in a white connector.
I would also wire a SPST switch in between the parking light wire and relay so that you can turn the foglights on / off. If you have just the relay the foglights will come on whenever the parking lights are on.
