Suspension noise?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2007, 08:38 AM   #1 (permalink)
Slemay
View Slemay's Photo Gallery
Gen5 Suspension noise??
I have a noise coming from my front right suspension.... when I hit some bumps I can hear a (keclunk) noise.... I've changed the mount, checked the strut all good... need input??
Slemay is offline   Reply With Quote
Old 08-21-2007, 12:09 AM   #2 (permalink)
View vin888's Photo Gallery
also have this problem on my 98 camry. i have monroe quick struts, new balljoint and stabilizer bar link. on my front left wheels. the noise i have is like something is loose when i hit speed bumps....
vin888 is offline   Reply With Quote
Old 08-21-2007, 09:00 AM   #3 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
I know this is a long shot, but I had something like this before on my gen3 before it died in a wreck -- it was the brakes on mine. Everytime I hit a speed bump or go over some pot hole or anything that impacted suspension, I hear a squeaking noise and a clunk noise from that part of the car. I had break service done and it was resolved.
Gellenole is offline   Reply With Quote
Old 08-21-2007, 12:48 PM   #4 (permalink)
Slemay
I got someone to check every bolt and made sure everything was looking good, no leaks nothing at all... still the noise, I might check the brakes then...
Old 08-27-2007, 12:17 AM   #5 (permalink)
slemay any updates? were you able the fixed your problem>
Old 08-27-2007, 09:25 AM   #6 (permalink)
Slemay
I was gone for the weekend so I didn't have time to look at it again... I might get sometime this week, I will let you know...
Old 08-27-2007, 07:23 PM   #7 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
It could be a few things, I know my strut was blown when my suspension started to clunk. I know you said the struts were good, but are you sure they arent leaking?
geoff5093 is offline   Reply With Quote
Old 08-28-2007, 11:20 AM   #8 (permalink)
View dchilders's Photo Gallery
Smile Strut mount is loose
The strut mount is loose, check it closely. I had the same problem on my wifes 98. The strut is fine but the mount is bad or loose.
dchilders is offline   Reply With Quote
Old 08-29-2007, 08:52 AM   #9 (permalink)
Slemay
I had my right mount replaced by toyota (30 minutes later after install still a noise) and they also checked the strut (no leaks by toyota)... I might check the engine bay maybe something inside is hitting...
Old 08-29-2007, 12:54 PM   #10 (permalink)
Slemay
Update: I recently pushed on the front right of the car and a little clicking noise is coming from the top of mount/shocks.... I'm going back to toyota and let them listen to this noise... hope it works....
Rear suspension noise tlwills 2nd Generation (2000-2004) 11 03-14-2012 11:05 PM
Suspension knocking noise aarong420 Archived Corolla threads 5 03-14-2007 12:49 PM
Suspension noise Trd_Thunder 2nd Generation (2005+) 4 05-10-2006 08:28 PM
Weird Suspension noise........ leasaunce Camry & Solara Lounge 4 08-16-2005 08:05 PM
suspension noise? Zer05 MR2 Forum 2 09-27-2004 12:19 AM
