On 2002-01-29 20:14, camkev wrote:
Cool, found it. It said If the stock tire size is 205/60/15 which is what i have right now and I go to a 215/40/18 all the numbers are very close. If you are saying that the tire will not be wide enough should i go with a 225? I don't want the tire to stick out of the wheel well. Right now the tire sets just inside the well. Should i get a certain offset or stick with stock?
What gen is it? Are you sure 205-60-15 is the stock size? Most Camrys have 205-65-15 if it is not equiped with 14s.
Rim sticking out more than the tire = looks bad and scuffs in no time
Chrome rims = ghetto and played out (IMHO) and heavy as a brick
If your tires stick out of the wheel well, that means the person who sold you the tires gave you the wrong offset.
The stock offset will not be the same on an 18" rims because it will be wider. If you know how offset is calculated, you'll know what I mean.
